Community Member
Cant resize disk using Gparted or LVM on Cisco UCS Central VM..
Hello folks,
  In order to upgrade to UCS Central 1.1 there is a requirement to increase the disk1 size to 40 GB from 20 GB as was needed before. Now when I try to use Gparted it doesnt recognize the partition (lists as unknown format )and therefore doesnt let me resize it. On the other hand I'm not sure how to access LVM to manage the disks from a UCS central VM (OVF). Any help would be appreciated.Thanks.
uzma
253
