09-24-2013 05:02 PM - edited 03-01-2019 11:16 AM
Is there anyway to assign Chassis ID higher than 40?
Thnaks
Hetal Soni
09-24-2013 06:06 PM
Hetal,
I am not sure, just because I have never had to do it before, but why would you need to do that if even with the new FIs the max you can support is 20 chassis?
http://www.cisco.com/en/US/products/ps11544/prod_models_comparison.html
If you need to, you may re-assign a chassis number that is not in use:
From the GUI:
Step 1 In the Navigation pane, click the Equipment tab.
Step 2 On the Equipment tab, expand Equipment > Chassis.
Step 3 Verify that the Chassis node does not include the following:
• The chassis you want to renumber
• A chassis with the number you want to use
If either of these chassis are listed in the Chassis node, decommission those chassis. You must wait until the decommission FSM is complete and the chassis are not listed in the Chassis node before continuing. This might take several minutes.
Step 4 On the Equipment tab, click the Chassis node.
Step 5 In the Work pane, click the Decommissioned tab.
Step 6 For the chassis that you want to renumber, do the following:
a. Right-click the chassis and choose Re-commission Chassis.
b. In the Chassis ID field of the Re-commission Chassis dialog box, type or use the arrows to choose the ID that you want to assign to the chassis
c. Click OK
Step 7 If Cisco UCS Manager GUI displays a confirmation dialog box, click Yes.
-Kenny
09-25-2013 04:51 AM
Thanks for response.
We would like to use Chassis ID 1-25 for Domain1 and 26 to 50 for Domain 2.
Hetal soni
09-25-2013 06:07 AM
Hetal,
Thanks for the clarification, what is the error that you see when you attemp to number the chassis higher than 40?
Are you, by any chance, using UCS central and see some particular error there?
-Kenny
09-25-2013 06:00 PM
Kenny,
Thanks for your response. UCSM doesn't allow to choose ID higher than 40. Currently, I am not using UCS Central.
Is it possible to open up enhancement request?
thanks
hetal
09-25-2013 09:44 PM
Hetal,
I will discuss the option with a colleague to see what can be done, but I am not sure unless there is a good demand from other customers to have this feature too, cause as I mentioned above, no more than 20 chassis are supported and there are no plans to increment that (at least now), however I understand you do not want more than 20 chassis per domain, the enhancement request may take that path.
You may contact your Cisco Rep to discuss further as he/she can address this in the best way and expose the situation and why it is a need for you.
-Kenny
