Community Member
Cisco ECDS UCS C22 M3 help
Hello
please help me .
I configured CIMC ( management IP) after that i configured CIMC  (remote presence) and i configured over serial (9600). After that i use  SSH , and i put connect host , but it requested to remove the   connection and use serial over lan. I need help to access MDE  configuration . I do not have any idea about KVM console cable and how  to connect .My solution to configure MDE devices which installed on UCS servers.
Thank you
1 REPLY
Community Member
Hi Kamel,
Please find the below link for UCS server configuration utility.hope it will help you.
http://www.cisco.com/en/US/partner/products/ps10493/products_user_guide_list.html
Gaurav
215
