10-06-2016 10:18 AM - edited 03-01-2019 12:55 PM
I have been newly install HX system version 1.7.3 finish
and Login to vSphere Web Client show internal error -
Unable to load resource module from /vshpere-client/pluginui/locales/StorvisorUi-zh_TW.swf
Vcenter version is 6.0U2
Is it mean not support tranditional chinese?
Solved! Go to Solution.
10-07-2016 12:24 PM
Did you successfully re-deploy your 1.7.3 HX cluster?
There's some cleanup that needed to be done in vCenter to clear the old information prior to re-deploying - such as removing the plugin from the vCenter MOB and deleting the HX cluster of the old cluster
10-10-2016 03:56 PM
Hi, stanleychou
HyperFlex is slated for language localization at later release (post 2.0) , which explains why you are getting this message
10-07-2016 12:24 PM
10-10-2016 03:56 PM
Hi Clifford
The vCenter is All new deploy, and try to re-deploy new vCenter and new 1.7.3 HX system 2 times.
and it continue appear error mesage.
10-10-2016 03:56 PM
Hi, stanleychou
