Cisco UCS network uplink on aggregation layer
Hello Cisco Community,
we are using our UCS (Version 2.21d) for ESX Hosts. Each host has 3 vnics as follows:
  • vnic 0 = VLAN 10 --> Fabric A, Failover Fabric B
  • vnic 1 = VLAN 20 --> Fabric B, Failover Fabric A
  • vnic 2 = VLAN 100 --> Fabric A, Failover Fabric B
Actually UCS is connected to the Access Layer (Catalyst 6509) and we are migrating to Nexus (vPC). As you know, Cisco UCS Fabric Interconnects can handle layer2 traffic itself. So we are planning to connect our UCS Fabric Interconnects directly to our new l3 nexus switch.
Does anyone have connect the UCS directly to l3? Do we have to pay attention to something? Are there some recommendations?
thanks in advance
best regards
/Danny
  • Unified Computing
Certain designs might require
Certain designs might require a L3 capable platform vide figure 1.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/UCS_CVDs/esxi51_n7k_metrocluster.pdf
What  are you trying to solve?
Thanks Marcin, I just want to
Thanks Marcin,
I just want to know, if I have to pay attention to something. vpc and so on. But if it is simple and I just have to connect my uplinks to the l3 nexus, its ok.
Just to collect some informations / experiences from other ucs users about connect ucs to l2 or directly to l3 :)
Ha! For most typical designs
Ha! For most typical designs (Flexpod, vblock) I would say, don't do it. L2 is typically faster.
It really depends on your business drivers. Talk to your SE, maybe it's better to sit down and divide and conquer.
VIP Red
Hi Danny !Which softswitch
Hi Danny !
Which softswitch are you using on ESXi ? vswitch, VMware DVS and / or N1k ?
my 2c
It is not best practise to use hardware fabric failover. Instead, use pair's of vnics, one connected to fabric A, resp B, and then let ESXi vswitch do the loadbalancing and failover.
Also, vPC is best practise to connect your FI's to Nexus (with L2 of course)
Walter.
Hi wdey, thanks for you
Hi wdey, thanks for you answer.
we are using ESXi 5.5 with dvswitche (distributed vswitch). In our cisco ucs powerworkshop, we discuss pros and contras of hard- and softwarefailover and we commit to use hardwarefailover. It is very fast and we have no problems actually.
Yesterday I updated UCS and restarted the FIs. No interruption of the VMs ;)
But about L3:
We only use "VLAN 10 / VLAN 20" in our vmware enviroment (UCS). VLAN 100 is not important, its management vlan. So if traffic has to leave the VM enviroment, it has to be routed in another vlan. So why it is not recommend to attach the ucs directly to the aggregation switch?
VIP Red
This is a neverending and misunderstood story: your design should provide load balancing AND failover. Hardware failover only gives you the latter.In your design, you just use one fabric per Vlan, what a waste !
And think about the situation of a failover on a ESXi host with 200 VM's; one has to send out at least 200 GARP messages, and this is load on the FI CPU. Most likely dozens or more ESXi server are impacted......
Cisco best practise: if you use softswitch, let it do the loadbalancing and failover, don't use hardware failover.
see attachment (the paper is not up to date,
For ESX Server running vSwitch/DVS/Nexus 1000v and using Cisco UCS Manager Version 1.3 and below, it is recommended that fabric failover not be enabled, as that will require a chatty server for predictable failover. Instead, create regular vNICs and let the soft switch send
gARPs for VMs. vNICs should be assigned in pairs (Fabric A and B) so that both fabrics are utilized.
Cisco UCS version 1.4 has introduced the Fabric Sync feature, which enhances the fabric failover functionality for hypervisors as gARPs for VMs are sent out by the standby FI on failover. It does not necessarily reduce the number of vNICs as load sharing among the fabric is highly recommended. Also recommended is to keep the vNICs with fabric failover disabled, avoiding the use of the Fabric Sync feature in 1.4 for ESX based soft switches for quicker failover.
Just to clear:Our enviroment
Just to clear:
Our enviroment consists two server Vlans, only for VMs!, 50% VMs on VLAN 10, 50%VMs on VLAN20 (historically). If we use NIC teaming for the servervlans, our "east/west traffic" within the same vlan may go out of the fabric interconnect to l2 switch and back to the other fabric interconnect. Very uncomfortable, not?
So we decided, to map VLAN 10 on Fabric A and VLAN 20 on Fabric B, both with hardware failover. So VLAN 10 will be switched inside Fabric Interconnect A, VLAN 20 will be switched inside Fabric Interconnect 20.
If we have just one server vlan, I understand the use of load-sharing and nic teaming. But in our case I think, fabric failover is the only thing.
For vMotion and Management (VLAN 100) its clear, one VLAN, only east-west traffic = single vnic with fabric failover.
So, now we are at the point, were east/west traffic of our VM servers will be switched inside their fabric interconnects. In that case, it is not necessary to connect the UCS to l2 switch, is it?
Please correct me, if I am wrong. I am not a network administrator ;) Just starting to understand networking :)
VIP Red
OK, I understand your design.
OK, I understand your design. However, the same result could be achieved with DVS and the proper design; eg.with different port groups with active A/ standby B, and vice versa. In my opinion, this software version is designed and managed by server folks; the hardware solution (UCS failover) is more network oriented, with some caveats that I mentioned above.
You need anyway a L2 connectivity from FI Northbound (perferred vPC); you are correct, however, even with your design, you might have failures, where some ESXi hosts switch from A to B, and therefore your traffic has to leave the UCS domain, and enter it again on the peer FI. e.g. a IOM - FI link of one chassis fails, or a FI port connecting a chassis fails. It is important that this external L2 connectivity is 10G and add's minimal additional hop count (vPC!); I had customers with external 1G connectivity, suddenly having performance problems ! I hope this should be clear by now ?
Of cource we are using 2x10G
Of cource we are using 2x10G each Fabric for uplink in a portchannel. (actually lacp / catalyst 6509e). With Nexus we will use vpc.
Yes I understand. But the traffic, which leaves the UCS domain, has to been routed, caus' it leave the VLAN / IP range, right? So the l2 switch will forward the packets to l3 and l3 send it "back" to l2 and destination.
l3 will be a nexus 5600 vpc pair, l2 are two  nexus 5600 vpc pairs, one per datacenter.
408
