Community Member
Cisco UCS
Looking for a Design Guide where I can see how exactly design and configure Cisco UCS Blade Series Servers with (2) 2200 IOMs to Fabric Interconnects.  I like to see how Fabric Interconnects connect to Cisco FEXs.
The design guides I have downloaded from Cisco only talks about Cisco FEXs at a very high level, not going into too much details how they connect to  Fabric Interconnects.
As I understand correctly, Fabric Interconnects itself have may server ports that connect down to Chassis IOMs.  Trying to understand how Server Ports on Fabric Interconnects can work inconjuction with Cisco FEXs.
Hi Abbasali, Cisco FEXes in
Hi Abbasali,
Cisco FEXes in UCS are use for C-Series server integrations. You won't be able use the FEXes to expand the number of ports on your fabric interconnect.
C-Series integration documentation below
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c-series_integration/ucsm2-1/b_UCSM2-1_C-Integration/b_UCSM2-1_C-Integration_chapter_01.html
Don't forget to rate any useful posts.
Community Member
fex can directly connect to
fex can directly connect to fabric interconnect
http://www.cisco.com/c/en/us/products/servers-unified-computing/ucs-5100-series-blade-server-chassis/ucs_kaon_model_preso.html
112
