configure to bring Fibre Channel between UCS Fiber Interconnect and Nexus 5548UP.
Shuja Tirmizi
using following  configuration between Nexus5k and UCS FI. the channel status comes to ini and change to notConnected .
fc1/31     431    F      on      notConnected     swl    --           100
fc1/32     431    F      on      notConnected     swl    --           100
 System version: 5.2(1)N1(1b)
fcoe                  1         enabled
fex                   1         enabled
fport-channel-trunk   1         enabled
interface-vlan        1         enabled
lacp                  1         enabled
lldp                  1         enabled
npiv                  1         enabled
sshServer             1         enabled
tacacs                1         enabled
telnetServer          1         enabled
udld                  1         enabled
vpc                   1         enabled
interface san-port-channel 100
  channel mode active
  switchport mode F
  switchport trunk allowed vsan 431
interface fc1/31
  switchport description "SAN PO to UCS -A"
  channel-group 100 force
  no shutdown
interface fc1/32
  no shutdown
interface fc1/31
  switchport mode F
interface fc1/32
  switchport mode F
Please help
19 Replies 19
can I use 5548up use as
A Fibre Channel Bridge connects an FCoE network to a Fibre Channel network.
Yes ! but.....
I would propose you do the following setup, instead of having a mix of FCoE and FC
- UCS FI in Fibrechannel end host mode (default)
- connect FI to N5k with classical FC
- This requires the N5k to be configured as NPIV
hi wdey,
5k is in NPIV mode
I cannot use FC between 5k to ucs, lack of 8gb sfp, 5k is in NPIV mode
ok, understand ! anyway, to solve an issue with hardware, a proper SFP, is much easier and cheaper than a software solution; do you have 4G SFP's ?
Which port type did you configure on the FI for the North bound FCoE link ? and what is the configuration of the peer port on the N5k ?
and How do i add this information in 5k
Add MAC OUI "002a6a", "8c604f", "00defb" ?
You have to upgrade your 5k to at least
6.0(2)N1(2)
