configuring uplink interface for UCS FIC-6120
I'm having issues trying to configure a basic uplink interface connection to my Cisco FIC 6120. I am not configuring the port-channel yet, but just an individual port for each FIC. The following are my configs.
interface GigabitEthernet7/39
switchport
switchport mode trunk
no ip address
spanning-tree portfast trunk
GigabitEthernet7/39 is down, line protocol is down (notconnect)
Hardware is C6k 1000Mb 802.3, address is d0d0.fcd.5b32 (bia
d0d0.fcbf.5b32)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s
input flow-control is off, output flow-control is desired
Clock mode is auto
Last input never, output never, output hang never
Last clearing of "show interface" counters 1y6w
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
I have configured a few other UCS's before this one, and I can not begin to
figure out the issue. I made sure that the SFP being used in the FIC is for
a LAN at 1 Gb speed, which matches what I have in the 6509. I also made
sure to specify the speed on the UCS at 1GB. But I did notice that the only setting for speed on the configured port on the 6509 is "speed nonegotiate".
On FI 6120, one of the first eight ports can only be configured for 1 Gbps.
http://www.cisco.com/en/US/prod/collateral/ps10265/ps10276/data_sheet_c78-524724.html
Please use one of the first 8 ports with GLC-T SFP on FI If it still fails, provide following output
show run int eth 1/X
show int eth 1/X
show int eth 1/X transceiver details
Padma
Re: configuring uplink interface for UCS FIC-6120
Everything is as should as far as the 1gb SPF placement on the fic. And sorry I could not paste the show run into this forum. I guess Cisco has a test limit.
FIC-1-A(nxos)# sh running-config interface ethernet 1/5
!Command: show running-config interface Ethernet1/5
!Time: Tue May 15 13:33:07 2012
version 5.0(3)N2(2.1x)
description U: Uplink
pinning border
switchport trunk native vlan 44
switchport trunk allowed vlan 1,12,44,90,100
speed 1000
no shutdown
FIC-1-A(nxos)# sh interface ethernet 1/5
Ethernet1/5 is down (Link not connected)
Hardware: 1000/10000 Ethernet, address: 547f.ee20.6b8c (bia
547f.ee20.6b8c)
Description: U: Uplink
Encapsulation ARPA
Port mode is trunk
auto-duplex, 1000 Mb/s, media type is 10G
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped never
30 seconds input rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
RX
0 jumbo packets 0 storm suppression packets
0 giants 0 input error 0 short frame 0 overrun 0 underrun 0
watchd
og 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble
0 Tx pause
0 interface resets
FIC-1-A(nxos)# sh interface ethernet 1/5 transceiver details
Ethernet1/5
transceiver is present
type is 1000base-SX
name is CISCO-AVAGO
part number is SFBR-5766PZ-CS1
revision is
serial number is AGM1421151Y
nominal bitrate is 1300 MBit/sec
Link length supported for 50/125um fiber is 550 m
Link length supported for 62.5/125um fiber is 270 m
cisco id is --
cisco extended id number is 4
Transceiver calibration is invalid
1101
