01-21-2014 06:10 AM - edited 03-01-2019 11:27 AM
I was wondering whether is possible to connect a tape library using FC directly to an FI 6248 in FC Siwtch mode.
01-22-2014 03:33 AM
Although technically it will work, it is most likely not supported/tested, not even recommended
01-22-2014 06:06 AM
Hi wdey,
But the hardware compatibility matrix includes a number of FC Tape libraries. So my guess is at least the devices which are included in the compatibility matrix should be able to be connected directly to the FI.
01-22-2014 06:22 AM
http://www.cisco.com/en/US/docs/unified_computing/ucs/interoperability/matrix/r_hcl_B_rel2.21.pdf
Enterprise Backup Interoperability Matrix
Table 8 lists the tape library models that are supported with this version of the Unified Computing System.
Note
Direct connect of tape libraries is not supported.
