03-02-2012 02:28 AM - edited 03-01-2019 10:18 AM
I know is possible to connect several EMC and NetApp NAS devices directly to UCS Fabric Interconnects. Question is:
Is it possible to directly connect an EMC Data Domain NAS, publishing CIFS/NFS shares?
Thanks a lot,
03-02-2012 04:45 AM
Hello Dani,
We can configure the FI ports as Appliance ports and connect NAS devices to it.
Padma
03-02-2012 04:47 AM
Correct, and as EMC Data Domain acts like a NAS device, my question was whether connecting EMC Data Domain to the Fabric Interocnnects is supported.
Is it?
03-02-2012 05:13 AM
Dani,
As long as it is IP based storage device, we support EMC and Netapp arrays for appliance ports.
Other vendor devices are not tested and hence not qualified for support.
Padma
03-02-2012 07:49 AM
Appliance ports work for almost anything. Have an Isilon system connected. Also have a Microsoft Storage Server attached.
Craig
03-06-2012 04:32 AM
Microsoft Storage Server?? Don't you guys say only EMC and NetApp arrays are supported??
03-06-2012 04:41 AM
Dani,
Any IP based storage array can work but officially supported deployments are arrays manufactured by EMC and Netapp vendors.
Padma
03-06-2012 04:51 AM
Ok, so even not officially supported, a 3rd party server like HP or DELL with a Windows File Server in it (for instance) will technically work fine in UCS?
03-06-2012 05:03 AM
Yes, it might work if the arrays follow standards for IP based storage connectivity.
03-20-2012 02:12 AM
Hi Craig,
Are you using a Nexus 22xx to connect to the Isilon system & Microsoft Storage Server? or direct to the appliance ports?
Kassim
