Datacentre interconnection option
Hi;
I have a requirement for a datacentre interconnection that the DCs are about 600km apart. Has anyone experienced the DCB (Datacentre Bridging) at close to this distance? or should I be looking at OTV ?
The features what I am looking between the DCs are:
Layer - 2 between the DCs
FCoE Between the DCs.
Daya
  • Unified Computing
1 REPLY
VIP Red
Hi Dayahttp://www.cisco.com/c
Hi Daya
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Data_Center/DCI/4-0/EMC/dciEmc.pdf
gives a good overview, although it refers to EMC as storage.
OTV doesn't have a distance limitation
The max. distance might be limited by the application, e.g. Sphere / vMotion
Regarding FCoE; todays FCoE implementations don't support 600 km; you have to extend classical fibrechannel with FCIP (dark fibre over this distance requires optical amplifiers, and therefore most likely comes from a service of a provider, and is rather expensive)
Walter.
32
