Does anyone know why sanboot redhat5 U7 OS kernel panic after running IO about 2 hours?
I sanboot installed redhat 5u7 x86_64 os on UCS, and then mapped 15 volumes to run IO,  os will become kernel panic less then 2 hours.
then I have to force power cycle the server.
The card used is M81KR.
Does anyone what is the problem? Thanks.
Feb 26 19:43:59 arcucsb200095e0 kernel: INFO: task kjournald:6427 blocked for more than 120 seconds.
Feb 26 19:43:59 arcucsb200095e0 kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Feb 26 19:43:59 arcucsb200095e0 kernel: kjournald     D ffffffff801546d1     0  6427    465          6430  6424 (L-TLB)
Feb 26 19:43:59 arcucsb200095e0 kernel:  ffff81066b6f1cf0 0000000000000046 000000006e420048 ffff8106853ea9d0
Feb 26 19:43:59 arcucsb200095e0 kernel:  00000001ffffffff 000000000000000a ffff810c6c31b080 ffff8106853f07a0
Feb 26 19:43:59 arcucsb200095e0 kernel:  00000184ac3ecc0b 0000000000000edf ffff810c6c31b268 0000000b1693b738
Feb 26 19:43:59 arcucsb200095e0 kernel: Call Trace:
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff8006ec8f>] do_gettimeofday+0x40/0x90
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff800155d3>] sync_buffer+0x0/0x3f
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff800637ce>] io_schedule+0x3f/0x67
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff8001560e>] sync_buffer+0x3b/0x3f
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff800639fa>] __wait_on_bit+0x40/0x6e
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff80063a94>] out_of_line_wait_on_bit+0x6c/0x78
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff800a2e8b>] wake_bit_function+0x0/0x23
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff88033a41>] :jbd:journal_commit_transaction+0x553/0x10aa
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff8003d85b>] lock_timer_base+0x1b/0x3c
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff8004ad98>] try_to_del_timer_sync+0x7f/0x88
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff88037662>] :jbd:kjournald+0xc1/0x213
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff800a2e5d>] autoremove_wake_function+0x0/0x2e
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff880375a1>] :jbd:kjournald+0x0/0x213
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff800a2c45>] keventd_create_kthread+0x0/0xc4
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff80032722>] kthread+0xfe/0x132
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff8005dfb1>] child_rip+0xa/0x11
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff80032624>] kthread+0x0/0x132
Feb 26 19:43:59 arcucsb200095e0 kernel:  [<ffffffff8005dfa7>] child_rip+0x0/0x11
Many thanks for your help.
Please provide following information
UCSM version
Blade model
CIMC, BIOS and M81KR adapter firmware version
ENIC and FNIC driver version
What type of storage are you trying to mount ?
Are you able to consistently reproduce the issue ?
Padma
Thanks for your help.
UCSM version   : 2.0(1s)
Blade model  :  Cisco UCS B2000 M1
CIMC: 2.0( 1q)
BIOS: S5500.2.0.1a.0.081120111606
and M81KR adapter firmware version :  2.0(1q)
ENIC and FNIC driver version: 5.0(3)N2(2.1s)
What type of storage are you trying to mount : The storage is IBM SVC.
Hello
You can get the driver version by executing following command in RHEL
modinfo enic
modinfo fnic
Can you consistently reproduce the crash ?
I am not aware of any known issues.
Please open a TAC service request with above information and also upload Redhat logs ( which can be collected by executing "  sosreport -k rpm.rpmva=off " command )
Padma
485
