Showing results forĀ
Search instead forĀ
Did you mean:Ā
Does the UCS C-Series Servers supports PCI/e card digium T1/E1
philip.cagunot
Does the UCS C-Series Servers supports/compatible with PCI/e card digium  TE407P/TE420 T1/E1.?
The server will be used as Asterisk server.
Philip
Brian Morrissey
Hi Philip,
Compatibility will depend on the server model that you have and whether the digium card is a full length, low profile, or half length pcie card.  Take a look at http://www.cisco.com/en/US/products/ps10493/prod_models_comparison.html#~tab-a for details.  If there are any issues with the card itself once it is installed it will have to go through the 3rd party manufacturer.
