11-11-2013 11:41 AM - edited 03-01-2019 11:20 AM
Where can I find Cisco UCS C-Series Rack-Mount UCS-Managed Server Software Drivers, e.g. W2012 R2
ISO image of UCS-related drivers ucs-cxxx-drivers.1.4.5b.iso | 13-JUN-2012 | 1908.21 MB |
Is shown as most recent ????
I also can't find the VIC-1225 ?
Solved! Go to Solution.
11-12-2013 10:34 AM
Hi Wdey,
The drivers for the 1225 vic card should already be included in the WINDOWS 2012 R2 ISO INSTALATON CD. If you see in our compatability matrix it says that it supports inbox drivers only. We do not have a specific bunlde with this drivers.
11-11-2013 04:35 PM
Hi Wedy,
What server do you have?
You should be able to use the drivers for the standalone version. See the link for the C220 M3 drivers bundle.
Cisco UCS C220 M3
11-11-2013 11:49 PM
Thanks Manuel
Nevertheless, it is very confusing, and above link should be updated accordingly, it's totally obsolete
11-12-2013 01:33 AM
When are the drivers for W2012 R2 for VIC-1225 available ?
The cannot be found in
ucs-cxxx-drivers.1.5.3a.iso 18-OCT-2013 3894.54 MB
11-12-2013 08:39 AM
Hi Wdey
According to the support Matrix, the drivers for Windows 2012 R2 are included in the installation ISO.
http://www.cisco.com/web/techdoc/ucs/interoperability/matrix/matrix.html
11-12-2013 10:29 AM
Please clarify ! where is W2012 R2 !
11-12-2013 10:34 AM
Hi Wdey,
11-12-2013 11:32 AM
Thanks Manual ! Indeed a complete new W2012 R2 fact: MSFT bundling UCS drivers with their iso distribution.
I hope this will also work for the upgrade from W2012 to W2012 R2
