EquipmentMissing after UCS upgrade to 2.2
Enviroment: 2 x FI6296; 2 x 5108 with 6 B200M3 each. All servers have 2 x 300 GB SAS local drive, RAID 1.
After upgrade to 2.2 one of servers indicates that local disks are missing (both of them). Invertory shows 0 disks in server. Two faults messages "Equipment Missing", code 1256, severity: info are shown in Faults tab.
Operating system is working, no problems detected.
  • Unified Computing
1 ACCEPTED SOLUTION
I have the same problem, 8 of
I have the same problem, 8 of my B200M3 servers Indicates that local disk are missing but the servers don't have any local disks.
Same here,...i have 2 FI
Same here,...
i have 2 FI pairs, each FI pair has 2 chassis, with 12 blades.
 Had only 8 blades per FI cluster before updating to 2.2, everything was fine - no localDisk message (F1256) on FabricInterconnect.
Did an update to 2.2 and attached a second chassis to each FI cluster => all new blades came up with the equipment-missing message (sys/chassis-X/blade-X/board/storage-SAS-1/disk-1/fault-F1256) as fault class info.
Removed an old blade from the old chassis and reinserted to the old slot ,... tadaaaaa same message as mentioned above.
So,.. for me it looks like that the version 2.2 is responsive for this behavior
cheers from austria
alex
I have the same issue with an
I have the same issue with an B200 M3 with no drives giving the F1256 error.  The service policy is set to No Local disks.  Is this a bug or have you been able to resolve the message, everything appears to be working fine.
Joe
VIP Red
which version of UCS ? 2.2.1d
which version of UCS ? 2.2.1d ?
We are running on 2.2(1c)...
We solved our issue by CIMC
We solved our issue by CIMC reset.
Equipment --> servers --> click on the server --> under gernal tab, in actions click on "Recover Server" --> select on reset CIMC
1093
