Error code: F1237. SASO_FAULT
I have received the following error code on one of our B200-M3 blades.  There were no changes made to UCS about which I am aware.  The LED on the front panel is green.  I did not receive a "call home" notification.  The error occurred several days ago.  There are no known functionality issues.  Google and Cisco Support searches were fruitless.
Description:  Health LED of server #/# shows error. Reason: SASO_FAULT:Sensor Failure Asserted;
Type: equipment
Cause: health-led-amber
Code: F1237
Severity:  Major
Does anyone have any insight as to the cause and remediation of this error?
Thank you. .. . . . ... .. . . . . . .        .. .. ..
Everyone's tags (3)
We need to check several things here:
What is the firmware version for UCSM, CIMC, bios and RAID controller for this server?
Do you see any event on SEL for sensor SASO_FAULT?
What is the HDD status for Disk 1 on UCSM?
Thank you for the response.
UCSM firmware version:  2.1(2a)
CIMC:  2.1(2a)
BIOS:  S5500.2.1.1b.0.020620132148
RAID controller (LSI):  Boot loader version:  06.34.00.00.   Running version: 01.32.09.00
Actual blade module (mistake made in original post):   B200-M2
Events on SEL on 12/2/13:
e9 | 12/02/2013 23:38:24 | System Mgmt Software | OS stop/shutdown #0x00 | OS Graceful shutdown | Asserted
ea | 12/02/2013 23:38:24 | OEM timestamped record: Type: DD: Mfg ID: 37 01 00:Raw SEL: EA 00 DD 50 6E 9D 52 37 01 00 00 FF 00 05 00 00
eb | 12/02/2013 23:38:29 | CIMC | Entity presence BIOS_POST_CMPLT #0x53 | Device Absent | Asserted
ec | 12/02/2013 23:40:33 | BIOS | System Event #0x83 | OEM System Boot Event | | Asserted
ed | 12/02/2013 23:40:34 | CIMC | Entity presence BIOS_POST_CMPLT #0x53 | Device Present | Asserted
ee | 12/02/2013 23:40:40 | CIMC | Drive slot(Bay) SAS1_FAULT #0x22 | Predictive Failure asserted | Asserted
ef | 12/02/2013 23:40:41 | CIMC | Platform alert LED_BLADE_STATUS #0x62 | LED color is amber | Asserted
f0 | 12/02/2013 23:40:41 | CIMC | Platform alert LED_SAS1_FAULT #0x65 | LED is on | Asserted
f1 | 12/02/2013 23:40:41 | CIMC | Drive slot(Bay) SAS0_FAULT #0x21 | Predictive Failure asserted | Asserted
f2 | 12/02/2013 23:40:41 | CIMC | Platform alert LED_SAS0_FAULT #0x64 | LED is on | Asserted
f3 | 12/02/2013 23:40:52 | CIMC | Drive slot(Bay) SAS1_FAULT #0x22 | Predictive Failure deasserted | Asserted
f4 | 12/02/2013 23:40:53 | CIMC | Platform alert LED_SAS1_FAULT #0x65 | LED is off | Asserted
f5 | 12/02/2013 23:40:53 | CIMC | Drive slot(Bay) SAS0_FAULT #0x21 | Predictive Failure deasserted | Asserted
f6 | 12/02/2013 23:40:53 | CIMC | Platform alert LED_BLADE_STATUS #0x62 | LED color is green | Asserted
f7 | 12/02/2013 23:40:54 | CIMC | Platform alert LED_SAS0_FAULT #0x64 | LED is off | Asserted
f8 | 12/02/2013 23:40:59 | System Mgmt Software | OS Boot #0x00 | C: boot completed | Asserted
f9 | 12/02/2013 23:40:59 | OEM timestamped record: Type: DC: Mfg ID: 37 01 00:Raw SEL: F9 00 DC EB 6E 9D 52 37 01 00 00 77 1A 9D 52 00
HDD status, Disk 1 (UCSM, Equipment tab> Inventory tab> Storage tab> Disks):  States, Operability:  Operable
Additional comments:
  • The "OS graceful shutdown" may have been related to a loss in SAN availability we experienced on 12/2/2013.  The SEL events are essentially identical to earlier OS restarts.  Identical events in the 12/2 restart are logged for SAS0 and SAS1.
  • The SAS0, Predictive Failure deasserted event leads me to believe that there is nothing wrong with the disk.  This may be a "false positive."
  • What does this additional information lead you to believe?
Thanks again .... . ....  . . ... . ... . . . . ..
There is a chance that the hard disk is getting predictive failures.
You can verify this by opening KVM, reboot server, press ESC at Cisco splash screen, then during POST press CTRL+C to access LSI Config Utility, go to RAID properties and check if any of the HDDs have 'Yes' under 'Pred Fail'.
If this is set to Yes, the hard disk needs replacement.
I plan to follow your advice and check the LSI utility to see if there is a disk failure being detected.  I will schedule a server downtime for this as soon as possible and report the results here.
Thanks again for the response.  .... . . . . .. ..   .. .. .. . .
I had encountered the same
I had encountered the same alert. Reset of CIMC fixed the alert.
2644
