01-09-2014 05:29 AM - edited 03-01-2019 11:26 AM
PFA screenshot of the error.. What excatly is the problem and how to solve the same ?
Solved! Go to Solution.
01-09-2014 01:41 PM
Shyam,
That is a sensor threshold crossed for Processor 1, please open a TAC case to have this analyzed and see if by any chance any of the hardware needs replacement.
-Kenny
01-21-2014 06:14 AM
Shyam,
This seems to be the same issue but on Processor 2, how often are you seeing this issue? Has this occurred only on these 2 blades? Are these 2 servers in the same chassis?
-Kenny
01-09-2014 01:41 PM
Shyam,
-Kenny
01-13-2014 01:11 AM
Thank you, Keny. Will raise a TAC case.
01-13-2014 05:47 AM
Shyam,
Sure, great. Please provide feedback once the issue is solved and mark the question as answered so users in the future can see you found the solution.
-Kenny
01-15-2014 12:08 AM
Sure.. have uplaoded the tech support file.. will update the results here..
01-17-2014 12:47 AM
The conclusion to the case was " Failed motherboard" and hence an RMA was provided.
01-17-2014 04:57 AM
Shyam,
Thansk for coming back and post the final solution, glad I helped somehow.
-Kenny
01-20-2014 11:35 PM
Keny,
Another blade with similar error and the error pops up and disapprears continuously.
Pasting sel info. Any advice ?
b8c | 01/17/2014 12:29:33 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
b8d | 01/17/2014 12:30:04 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
b8e | 01/17/2014 12:30:04 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
b8f | 01/17/2014 12:32:03 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
b90 | 01/17/2014 12:32:03 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
b91 | 01/17/2014 12:32:07 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
b92 | 01/17/2014 12:32:07 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
b93 | 01/17/2014 12:39:47 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
b94 | 01/17/2014 12:39:47 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
b95 | 01/17/2014 12:40:33 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
b96 | 01/17/2014 12:40:33 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
b97 | 01/17/2014 12:41:24 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
b98 | 01/17/2014 12:41:24 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
b99 | 01/17/2014 12:41:35 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
b9a | 01/17/2014 12:41:35 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
b9b | 01/17/2014 12:42:43 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
b9c | 01/17/2014 12:42:43 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
b9d | 01/17/2014 12:42:48 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
b9e | 01/17/2014 12:42:48 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
b9f | 01/17/2014 13:13:08 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
ba0 | 01/17/2014 13:13:08 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
ba1 | 01/17/2014 13:13:19 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
ba2 | 01/17/2014 13:13:19 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
ba3 | 01/17/2014 13:14:30 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
ba4 | 01/17/2014 13:14:30 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
ba5 | 01/17/2014 13:14:34 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
ba6 | 01/17/2014 13:14:34 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
ba7 | 01/17/2014 13:18:12 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
ba8 | 01/17/2014 13:18:12 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
ba9 | 01/17/2014 13:18:23 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
baa | 01/17/2014 13:18:23 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
bab | 01/17/2014 13:19:14 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bac | 01/17/2014 13:19:14 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
bad | 01/17/2014 13:19:36 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
bae | 01/17/2014 13:19:36 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
baf | 01/17/2014 13:20:02 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bb0 | 01/17/2014 13:20:02 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
bb1 | 01/17/2014 13:20:24 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
bb2 | 01/17/2014 13:20:24 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
bb3 | 01/17/2014 13:20:33 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bb4 | 01/17/2014 13:20:33 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
bb5 | 01/17/2014 13:20:44 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
bb6 | 01/17/2014 13:20:44 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
bb7 | 01/17/2014 13:21:24 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bb8 | 01/17/2014 13:21:24 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
bb9 | 01/17/2014 13:21:26 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
bba | 01/17/2014 13:21:26 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
bbb | 01/17/2014 13:21:52 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bbc | 01/17/2014 13:21:52 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
bbd | 01/17/2014 13:22:56 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
bbe | 01/17/2014 13:22:56 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
bbf | 01/17/2014 13:23:38 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bc0 | 01/17/2014 13:23:38 | CIMC | Event Logging Disabled SEL_FULLNESS #0x8a | SEL Full | | Asserted
01-21-2014 06:14 AM
Shyam,
-Kenny
01-21-2014 07:03 AM
The error keeps on appearing and disapprearing.
Only to these two blades
They are in different chasis.
01-21-2014 07:39 AM
Shyam,
Ok, nice... Is the replaced blade is still throwing these messages intermittently?
-Kenny
01-23-2014 04:51 AM
the balde with the replaced motherboard is all fine now.
01-23-2014 04:55 AM
Shyam,
If they were on different chassis and the replaced one is fine, I would consider that only a coincidence.
-Kenny
