Error on B200 M3
PFA screenshot of the error.. What excatly is the problem and how to solve the same ?
2 ACCEPTED SOLUTIONS
Error on B200 M3
Shyam,
That is a sensor threshold crossed for Processor 1, please open a TAC case to have this analyzed and see if by any chance any of the hardware needs replacement.
-Kenny
Error on B200 M3
Shyam,
This seems to be the same issue but on Processor 2, how often are you seeing this issue?  Has this occurred only on these 2 blades?  Are these 2 servers in the same chassis?
-Kenny
Error on B200 M3
Shyam,
-Kenny
Error on B200 M3
Thank you, Keny. Will raise a TAC case.
Error on B200 M3
Shyam,
Sure, great.  Please provide feedback once the issue is solved and mark the question as answered so users in the future can see you found the solution.
-Kenny
Error on B200 M3
Sure.. have uplaoded the tech support file.. will update the results here..
Error on B200 M3
The conclusion to the case was " Failed motherboard" and hence an RMA was provided.
Error on B200 M3
Shyam,
Thansk for coming back and post the final solution, glad I helped somehow.
-Kenny
Error on B200 M3
Keny,
Another blade with similar error and the error pops up and disapprears continuously.
Pasting sel info. Any advice ?
b8c | 01/17/2014 12:29:33 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
b8d | 01/17/2014 12:30:04 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
b8e | 01/17/2014 12:30:04 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
b8f | 01/17/2014 12:32:03 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
b90 | 01/17/2014 12:32:03 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
b91 | 01/17/2014 12:32:07 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
b92 | 01/17/2014 12:32:07 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
b93 | 01/17/2014 12:39:47 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
b94 | 01/17/2014 12:39:47 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
b95 | 01/17/2014 12:40:33 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
b96 | 01/17/2014 12:40:33 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
b97 | 01/17/2014 12:41:24 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
b98 | 01/17/2014 12:41:24 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
b99 | 01/17/2014 12:41:35 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
b9a | 01/17/2014 12:41:35 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
b9b | 01/17/2014 12:42:43 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
b9c | 01/17/2014 12:42:43 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
b9d | 01/17/2014 12:42:48 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
b9e | 01/17/2014 12:42:48 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
b9f | 01/17/2014 13:13:08 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
ba0 | 01/17/2014 13:13:08 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
ba1 | 01/17/2014 13:13:19 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
ba2 | 01/17/2014 13:13:19 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
ba3 | 01/17/2014 13:14:30 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
ba4 | 01/17/2014 13:14:30 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
ba5 | 01/17/2014 13:14:34 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
ba6 | 01/17/2014 13:14:34 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
ba7 | 01/17/2014 13:18:12 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
ba8 | 01/17/2014 13:18:12 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
ba9 | 01/17/2014 13:18:23 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
baa | 01/17/2014 13:18:23 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
bab | 01/17/2014 13:19:14 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bac | 01/17/2014 13:19:14 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
bad | 01/17/2014 13:19:36 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
bae | 01/17/2014 13:19:36 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
baf | 01/17/2014 13:20:02 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bb0 | 01/17/2014 13:20:02 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
bb1 | 01/17/2014 13:20:24 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
bb2 | 01/17/2014 13:20:24 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
bb3 | 01/17/2014 13:20:33 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bb4 | 01/17/2014 13:20:33 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
bb5 | 01/17/2014 13:20:44 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
bb6 | 01/17/2014 13:20:44 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
bb7 | 01/17/2014 13:21:24 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bb8 | 01/17/2014 13:21:24 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
bb9 | 01/17/2014 13:21:26 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
bba | 01/17/2014 13:21:26 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
bbb | 01/17/2014 13:21:52 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bbc | 01/17/2014 13:21:52 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is amber | Asserted
bbd | 01/17/2014 13:22:56 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Deasserted | Reading 1.04 <= Threshold 1.05 Volts
bbe | 01/17/2014 13:22:56 | CIMC | Platform alert LED_BLADE_STATUS #0x95 | LED color is green | Asserted
bbf | 01/17/2014 13:23:38 | CIMC | Voltage P1V05_VTT_P2 #0x10 | Upper critical - going high | Asserted | Reading 1.05 >= Threshold 1.05 Volts
bc0 | 01/17/2014 13:23:38 | CIMC | Event Logging Disabled SEL_FULLNESS #0x8a | SEL Full |  | Asserted
Error on B200 M3
Shyam,
-Kenny
Error on B200 M3
The error keeps on appearing and disapprearing.
Only to these two blades
They are in different chasis.
Error on B200 M3
Shyam,
Ok, nice... Is the replaced blade is still throwing these messages intermittently?
-Kenny
Error on B200 M3
the balde with the replaced motherboard is all fine now.
Error on B200 M3
Shyam,
If they were on different chassis and the replaced one is fine, I would consider that only a coincidence.
-Kenny
1179
