Error upgrading nexus 1000v: ERROR: Cannot remove system vlans, port-profile currently in use by interface xxx
Upgrading the nexus 1000v, we wran the pre-upgrade utility which failed at step 7 with this error:
 CHECK 7:
Checking for Non-system Native Vlans in System Port-profiles....
Note: The duration of this check depends on the size of the running configuration.
##                           FAIL                                            ##
## The following list of system port-profiles have respective non-system     ##
## vlan as native vlan:                                                      ##
 1: Port-profile: 'DATA-UPLINK',  Native Vlan: '1'.
##  Corrective Measures:                                                     ##
## Before upgrading the Nexus1000v to 4.2(1)SV1(4b) user MUST convert the    ##
## above listed non-system native vlans in the respective port-profiles to   ##
## system vlan using the command 'system vlan <vlan-list> '.                 ##
## Please re-run the script after making above changes.                      ##
Then we tried to fix it as suggested but we got an error message:
ERROR: Cannot remove system vlans, port-profile currently in use by interface  Eth3/1
Could you help us to understandi what happened and solve the problem?
Is strictly necessary to fix the problem showed by pre-upgrade utility?
Thank You
Mauro
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: Error upgrading nexus 1000v: ERROR: Cannot remove system vla
Yes, that is correct. "system vlan 1,3205-3206,3211-3212" is what you would need. This page talks about the guidelines/limitations when dealing with system VLANs:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus1000/sw/4_2_1_s_v_1_4_a/port_profile/configuration/guide/n1000v_portprof_4system_external_docbase_0900e4b181f8103d_4container_external_docbase_0900e4b1822edb9c.html
It also talks about why you cannot enter just 'system  vlan 1' and end up erasing the other existing ones.
Shankar
Hello Mauro,
The error is reported when the pre-upgrade script detects a non-system native vlan:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus1000/sw/4_2_1_s_v_1_4_b/upgrade/software/guide/n1000v_upgrade_software.html#wp646262
I believe you have explicitly configured VLAN 1 as the native VLAN on the port-profile named DATA-UPLINK. Please confirm this. If yes, then your options are:
- Configure 'default switchport trunk native vlan' in the port-profile. But this might cause a link flap due to CSCtr97841
- Configure 'system vlan 1,' in the port-profile -> Is this what you are doing?
- Ignore the error as long as you are not using VLAN 1 and config matches on the upstream switchport.
Shankar
Hi Sprasath,
I "inerhited" the 1000v configuration so I can't tell you hat they thopught when they configured VLAN1.
Unluckily I'm not a netwrok administrator so I bumped in this problem and I'm trying to deal whith it.
I was trying to configure 'system vlan 1' as suggetsed in the pre-upgrade checking tool pheraphs I didn't undertand command syntax.
Looking at your suggestion I uderstood my error because writing:
"system vlan 1" actually adds system VLAN 1 in the system VLANs but in the meanwhile take off the "unwritten" vlans that I already have configured isn't it?
Looking at the switch configuration I can see:
show port-profile name DATA-UPLINK
port-profile DATA-UPLINK
  description:
  type: ethernet
  status: enabled
  capability l3control: no
  pinning control-vlan: 0
  pinning packet-vlan: 0
  system vlans: 3205-3206,3211-3212
  port-group: DATA-UPLINK
  max ports: -
  inherit:
  config attributes:
    switchport mode trunk
    switchport trunk native vlan 1
    switchport trunk allowed vlan 1,5,8,10,12,2000,3000,3205-3206,3211-3212
    channel-group auto mode on mac-pinning
    no shutdown
  evaluated config attributes:
    no shutdown
  assigned interfaces:
    port-channel1
    port-channel2
    port-channel3
    port-channel4
    port-channel5
    port-channel6
    port-channel7
    port-channel8
    Ethernet3/1 (member of port-channel1)
    Ethernet3/2 (member of port-channel1)
    Ethernet4/1 (member of port-channel3)
    Ethernet4/2 (member of port-channel3)
    Ethernet5/1 (member of port-channel4)
    Ethernet5/2 (member of port-channel4)
    Ethernet6/1 (member of port-channel2)
    Ethernet6/2 (member of port-channel2)
    Ethernet7/1 (member of port-channel5)
    Ethernet7/2 (member of port-channel5)
    Ethernet8/1 (member of port-channel6)
    Ethernet8/2 (member of port-channel6)
    Ethernet9/1 (member of port-channel7)
    Ethernet9/2 (member of port-channel7)
    Ethernet10/1 (member of port-channel8)
    Ethernet10/2 (member of port-channel8)
So should the complete command be somethin like:
"system vlan 1,3205-3206,3211-3212"?
Thank You
Mauro
Shankar
1227
