04-17-2014 01:06 PM - edited 03-01-2019 11:37 AM
I have a UCS 5108 chassis with two B200 M3 server blades and FabricInterconnect 6248 (no expansion module) with 2.2(1d) version running. I have installed ESXi 5.1 on both blades. Now I can add one of the ESX host to my vCenter, but the other one is not accessable even not responding to ping.
I have compare the configuration on both blade and I couldn't find anything. Please let me know if you have any experience with this.
Solved! Go to Solution.
04-18-2014 12:59 AM
If native vlan is not selected, did you specify vlan in the ESXi configuration ?
The following combinations work
native vlan selected -- no vlan specified in ESXi
no native vlan selelcted -- vlan specified in ESXi
Therefore the remark on the screenshot (vlan optional) is very misleading; in the latter case it is actually mandatory
Did you install ESXi on the local disk ?
04-17-2014 03:59 PM
Hi Kshahfari,
Are these two servers using the same service profile?
Verify that the vnic(s) of the server that doesn't respond to pings have the proper vlan information.
04-17-2014 04:22 PM
Hi manvelas,
No each one has its own service profile. they are all in default vlan 1.
04-17-2014 04:39 PM
Compare, each vlan on both profiles and make sure they have the same configuration, pay attention to the Native Vlan box (see native_vlan screenshot).
Now on you ESXi host make sure you have the correct setting for the vlan configuration and ip. (See ESXi_vlan) screenshot
04-17-2014 05:28 PM
They both are on vLAN 1 with native_vlan box unchecked.
I also checked the ESXi hosts and they have same setting for the vlan and each has it's own ip addresses.
Still no luck!
04-17-2014 07:20 PM
Try to decommission and re-ack the server that is not working. Decommissioning the server will reboot it, so power off the esxi server first.
Also are these servers booting of a SAN or local
04-17-2014 07:39 PM
decommission and re-ack didn't help.
servers are booting of local.
04-17-2014 08:25 PM
Have you tried to swap the service profiles between these two blades to check if the issue follows the blade or the service profile configuration?
04-18-2014 12:59 AM
04-18-2014 08:53 AM
Hi wdey,
first combination worked. ESXi had vlan configured to default (1), but after taking that out I can add it to vCenter.
Only issue is after I swapped back the service profile, ESXi gets back to the vlan 1. does that mean everytime that server gets reboot it I will get same issue?
04-18-2014 08:48 AM
Hi manvelas,
swapping service profile didn't help.
04-18-2014 08:53 AM
What do you mean? Do you mean that after you swap the service profiles the same blades still have the same problem?
If after swapping the service profiles, the same blades has the same problem, it means that the issue is related with the Blade/adapter or the OS/configuration installed this blade.
In the firmware on both of this blades at the same level (see share some screenshots)
04-18-2014 11:15 AM
I mean after I swapped the service profile. same IP address of ESXi host was accessiable and I was able to add the host to vCenter, where the other one wasn't. but after I check the native vlan on the server and took out the vLAN on ESXi host it worked. and both servers now added to my vCenter.
