08-17-2014 08:33 PM - edited 03-01-2019 11:48 AM
Hi all,
I've got 4 x B200M3 blades running ESXi 5u2 in a single UCS chassis. These run a number of vSwitches, and all of the connected vmnics show 40000 Mb full duplex (as expected).
Yesterday I added 2 more B200M3's (to slot 7 and 8), and I'm only getting 20000 Mb on all vmnics. The the hosts are configured the same as the old via vCenter (although not using Host Profiles), and the UCS Service Profiles on the new blades are clones from an existing blade.
See screenshots attached....
Does anyone have some idea of what that could be? Any assistance would be great.
Cheers
Solved! Go to Solution.
08-17-2014 09:03 PM
One more thing, you might be hitting the defect below if you have the same hardware on all of the blades including the two new b200 M3.
You may also see the bandwidth difference if the new cards are missing one of the adapters, it could be the port expander or the 1280 or 1240 vic, then is an expected behavior.
08-17-2014 09:00 PM
What firmware version does your UCS is running?
It is possible that you servers might be hitting the defect below:
Line-rate in policy limits the vnic speed to 10-G rate for VIC 1240/1280
https://tools.cisco.com/bugsearch/bug/CSCun79957
Please let me know if this helps
08-17-2014 09:25 PM
Hi manvelas & thanks for the response.
The UCS Infrastructure firmware version is 2.2(2c), the new blades are running 2.2(1d). The 4 older blades are still running 2.1(1e).
The 2 new blades have the 1240 VIC (cisco part: UCSB-MLOM-40G-01)
08-17-2014 09:03 PM
08-18-2014 01:07 AM
You're spot on manvelas - didn't think to check, but our supplier missed the additional mezz card on these 2 units. The part we're missing to allow 40gb is: Cisco UCS Port Expander Card (mezz) for VIC 1240 modular LOM (Cisco part: UCSB-MLOM-PT-01)
Thanks for your help mate.
08-17-2014 10:26 PM
