ESXi VNIC speed dropped after 2.2.2c upgrade
I am hoping somebody can help me, i just finished upgrading UCS to 2.2.2c and noticed that my ESXi hosts (B200M3 with 1240 adapters) dropped the speeds from 40000 to 10000.  I came across this bug https://tools.cisco.com/bugsearch/bug/CSCun21077 but my firmware and drivers are newer (2.2.2c and 2.1.2.50).  Anybody else run into this?
1 ACCEPTED SOLUTION
If you are hitting the bug
If you are hitting the bug mentioned, then I assume you have QoS policies applied to the vnics? Change the Rate (Kbps) from line-rate to 40000000. The speed presented to VMware will change immediately. Unfortunately appears that line-rate on a few of the 2.2 releases actually means 10GbE.
Hi, You have adapters 1280
You have adapters 1280 AND 1240 or just 1240 in your servers ?
-Kenny
1240 only, i notice speed
1240 only, i notice speed dropped once the first FI got upgraded and restarted, all of mine VMware virtual switches were showing one link at 10000 and the other at 40000 or 20000 depending which server it was.  Once the second FI was upgraded all virtual switches were reporting two vNICs at 10000.  Really bummer with this upgrade so far.
VIP Green
I don't comment on the bug;
I don't comment on the bug; but on the different speeds shown in ESXi 10000, 20000, 40000
This has been discussed in
https://supportforums.cisco.com/discussion/12200821/nics-esxi-show-40000-and-10000
Thanks but solution in that
Thanks but solution in that article did not work for me.
Can you share a screenshot of
Can you share a screenshot of your QoS policy?
And can you put 1 ESXi host into maintenance mode, remove the QoS policy and reboot and advise if this removes the 10GbE cap.
Matt,I already verified that
Matt,
I already verified that your suggestion works, i actually don't even have to restart a server i can just change the QoS policy to not set and speed on virtual switch goes back to normal.  However in my environment i have two types of server that share that policy so i need to duplicate them because some servers should have speed of 20000 and some 40000.  Thanks a lot for you help.
No worries, I thought this
No worries, I thought this would fix it. You should be OK using 1 QoS policy at 40GbE. To my understanding it is an upper limit so if you are limited by the hardware then it will just step down. Easy to test out as you know, no reboot required for it.
It worked thanks again for
It worked thanks again for your help Matt!!!
535
