Excessive AD login attempts
Brad_80
We have a UCS system configured for LDAP authentication against Active Directory. Everything is working as expected, but on the DCs we are seeing excessive failed login attempts originating from the fabric interconnect IPs against an invalid domain account. We are seeing anywhere from hundreds to thousands of attempts per day, so I don't believe these are due to invalid GUI login attempts or anything user driven. I've dug through the GUI but cannot find anything that would be using that account. The BindDN is set to use a different account created solely for this purpose. An example from the event log is posted below (192.168.32.12 is the primary FI). Any thoughts?
An account failed to log on.
Subject:
    Security ID:        SYSTEM
    Account Name:        LP-DC02$
    Account Domain:        CO
    Logon ID:        0x3e7
Logon Type:            3
Account For Which Logon Failed:
    Security ID:        NULL SID
    Account Name:        Admin
    Account Domain:        CO
Failure Information:
    Failure Reason:        Unknown user name or bad password.
    Status:            0xc000006d
    Sub Status:        0xc000006a
Process Information:
    Caller Process ID:    0x1dc
    Caller Process Name:    C:\Windows\System32\lsass.exe
Network Information:
    Workstation Name:    LP-DC02
    Source Network Address:    192.168.32.12
    Source Port:        43342
Detailed Authentication Information:
    Logon Process:        Advapi
    Authentication Package:    MICROSOFT_AUTHENTICATION_PACKAGE_V1_0
    Transited Services:    -
    Package Name (NTLM only):    -
    Key Length:        0
This event is generated when a logon request fails. It is generated on the computer where access was attempted.
The  Subject fields indicate the account on the local system which requested  the logon. This is most commonly a service such as the Server service,  or a local process such as Winlogon.exe or Services.exe.
The Logon Type field indicates the kind of logon that was requested. The most common types are 2 (interactive) and 3 (network).
abbharga
Level 4
Level 4
Hi Brad,
I checked my lab setup and do not see anything similar, can you let me know the UCSM version and i can check for that specific version.
Is there is any other AD intergation? back-up job? KVM access etc?
feel free to open a TAC case if you wish to and we should to able to look into the logs and figure out if there is a request going out from UCS for authentication of a specific account.
Thanks!
./Abhinav
