Extract UCS Stats?
I would like to create a process to extract UCS statistics to an external DB or spreadsheet to perform long term trending & analysis? Does anyone know if there is a way to extract UCS statistics ??
Bud
  • Unified Computing
Everyone's tags (2)
1 REPLY
Extract UCS Stats?
Hi Robert,
You could manually export the statistics to CSV format in the UCSM gui for each object (chassis, fabric interconnect etc).
The other option is to write a script using the UCS Powertool for Powershell
(http://developer.cisco.com/web/unifiedcomputing/pshell-download).
You would just basically need to do something like the following:
Connect-UCS 10.10.10.10
Get-UcsStatistics | Where {$_.dn -like "fabric/lan/*/tx-stats"} | select Dn,TimeCollected,TotalPackets,JumboPackets | Export-Csv JumboStats.csv
383
