F0531 error - RAID battery inoperable
I see these 2 errors in few of our blades after upgrading them to 2.1(3a).
F1237 - Health LED of server 1/1 shows error. Reason:RAID_BATT_FLT:Sensor Failure Asserted;
F0531 - RAID Battery on server 1/1 operability:inoperable. Reason:
Any inputs on these errors?
Subbu
Hi Sye,
What type of server is this?
This may be related to a bug depending on the server, etc.Typically, if the logs are not showing an actual hardware fault, in that scenario, decomissioning the blade and re-acknowledging it and or trying to reset the CMOS, might resolve it.
Thanks.
-Bruce
Hi Sye,
This error is most commonly seen when the battery needs to be replaced in a UCS B440.
Fault Code:F0531
Message
This fault occurs when the RAID battery voltage is below the normal operating range.
Recommended Action
Step 1 Replace the RAID battery.
Step 2 If the above action did not resolve the issue, create a show tech-support file and contact Cisco TAC.
Here is the battery location:
Chris,
Hi Chris,
Is there a way to confirm if the battery needs a replacement? Or is it always assumed that it needs to be replaced for the fault code:F0531?
Subbu
939
