08-23-2012 01:11 PM - edited 03-01-2019 10:35 AM
I'm adding a UCS-FI-E16UP= expansion module to an exisiting operating 6296. I couldn't tell from the installation instructions if this module can be hot inserted into an operating 6296. Can it?
Solved! Go to Solution.
08-23-2012 01:33 PM
They "should" be but I will need to confirm. I do know that during a unified port change just the module reboots, and then comes back online (without a whole FI reboot) so my gut says yes they are hot swap.
I've checked all our guides on CCO and don't see a definate answer. Let me get a firm answer for you, and then get our docs update accordingly.
Edit: Found that the 5500's are hot swap, so the 6200 will be also. They're based on the same platform.
Expansion modules allow the Cisco Nexus 5596UP switch to be configured as cost-effective 10-Gigabit Ethernet switches and as I/O consolidation platforms with native Fibre Channel connectivity.
The Cisco Nexus 5596UP switch has three slots that can be used for the following optional expansion modules:
•16-port Universal (Fibre Channel and Ethernet) GEM (N55-M16UP) that provides 8-, 4-, 2-, or 1-Gbps Fibre Channel and 1- or 10-Gigabit Ethernet ports
•Layer 3 GEMs (N55-M160L3 and N55-M160L3-V2) provide 160 Gbps of Layer 3 services. The N55-M160L3-V2 uses a newer version of the Layer 3 ASIC that enables higher table sizes in a future software release from 8K host entries to 16K host entries or from 4K multicast routes to 8K multicast routes (IPv4).
You can hot swap the expansion modules during operations.
Robert
08-23-2012 01:33 PM
Robert
08-23-2012 01:57 PM
Thanks Robert. I just inserted them and they are recognized under UCS Manager. Version is 2.0(3a) by the way.
