Fabric Interconnect Uplink port channeling...
Network Group
We setup port channel of two 10G uplink interfaces on each Fabric Interconnect. Everything is running as expected.
However we noticed that under 'Port-Channel # (Fabric #)' setting on LAN tap, 'Admin Speed' was set to '10Gbps'.
Should we leave this configuration as is or match to the maximum bandwidth of port Channel we set up (20Gbps)?
I only see four options on each port channel configuration, 1 Gbps, 10Gbps, 20Gbps and 40Gbps so I'm not sure if we should change this setting.
Thank you
6 Replies 6
padramas
You do not need to change the speed ( admin ). 20 Gbps configuration is applicable for certain server models.
--------  NXOS output -----------------
FI-A(nxos)# sh run int port-channel 1
interface port-channel1
  description U: Uplink
  switchport mode trunk
  speed 10000
FI-A(nxos)# show int port-channel 1
port-channel1 is up
  Hardware: Port-Channel, address: 547f.ee67.e0fb (bia 547f.ee67.e0fb)
  Description: U: Uplink
  MTU 1500 bytes, BW 20000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s
FI-A(nxos)# sh int bri
Port-channel VLAN  Type Mode   Status  Reason                    Speed  Protocol
Interface
Po1          1     eth  trunk  up      none                       a-10G(D)  lacp
There is cosmetic defect where we list the operational speed as 10 Gbps instead of 20Gbps
FI-A /eth-uplink/fabric # show port-channel detail
Port Channel:
    Port Channel Id: 1
    Admin State: Enabled
    Oper State: Up
   Speed: 10 Gbps
    Oper Speed: 10 Gbps
    State Reason:
    flow control policy: default
Padma
Hi Padma,
The Admin Speed settings 1/10/20/40 Gbps are availbale on physical interfaces from GUI as shown in your screen-shot. Just wondering where would 20 and 40 Gbps gets applied! I think no documentation is availble in the public domain in Cisco site. Can you please lead me to any documentation on this?
Thanks in adavance,
Shine
Hello Shine,
The current generation of hardware does not support 20 / 40 Gbps ports but software was developed to be future-proof :-)
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCub47897
Port channel operational speed would reflect correct value in next major software release version.
Padma
Hi Padma,
Thanks for the response.
This Admin Speed is availablable not just on port-channel interfaces, but on physical interfaces as well. What confuses me is, I haven't heard of a 20Gbps Ethernet standard. The bug id is talking about Operational Speed not the Admin Speed. I was referring to the Admin Speed that you can set as part of configuration.
Can you please clarify above?
Thanks in advance again.
Cheers,
Shine
Hello Shine,
Some adapters do support 20 Gbps and they are available in UCSM for such hardware.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtt98475
Resulted in updating the doc with following note
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/gui/config/guide/2.0/b_UCSM_GUI_Configuration_Guide_2_0_chapter_0101.html
The admin speed can be changed only for certain ports, and not all  speeds are available on all systems. For more information, see the Hardware Installation Guide for your fabric interconnect.
http://www.cisco.com/en/US/prod/collateral/modules/ps10277/ps12377/data_sheet_c78-699459.html
/chassis/server # show adapter detail
Adapter:
    Product Name: Cisco UCS VIC 1240
    PID: UCSB-MLOM-40G-01
    VID: V00
    Vendor: Cisco Systems Inc
    Product Description: PCI Express Dual Port Cisco Converged Network Adapter Supporting 20Gb Ethernet and 20Gb Fibre Channel
Padma
Hi Padma,
The card "VIC 1240" supports 4 x 10Base-KR or 8 x 10Base-KR (with expansion card). The adapter doesn't support 20Gbps on a single physical interface. The bug ID CSCtt98475 says 20Gbps will never exist. So I can't see a reason why the option of Admin Speed 20Gbps on physcial port required - EVER.
I don't believe the  following statement is accurate from a physical interface perspective
"Some adapters do support 20 Gbps and they are available in UCSM for such hardware."
Thanks and best reagrds,
Shine
