Showing results forĀ
Search instead forĀ
Did you mean:Ā
FC Port-Channel not working with BIOS v.3.6.0
ataranen
I have downgraded one of the new FIs (6248UP) I just purchsed from version 2.1 to 2.0(5a). It is  connected in a cluster with another 6248UP. The only difference between them is the BIOS version - the new 3.6.0 the old 3.5.0. The FC port-channel on the new FI refuses to work. The FC connections without port-channel work fine and register with NPIV mds switch, but the port-channel always shows Link Failure after it tries to come up for about 3 minutes. Anyone has an idea why FI downgraded from 2.1 to 2.0 won't function for FC port-channel?
5 Replies 5
Manuel Velasco
Hi Ataranen,
Was the fabric able to form the port-channel with the MDS switch when the fabric was running firmware 2.1?
Where do you see the firmware version on the fabric?
Can you run the following command on the fabric interconnect that is not able to form the port channel?
F-A# connect nxos
F-A(nxos)#show interface eth 1/1
What is the model of your MDS switch?
What software version is the MDS running?
I didn't test it with firmware 2.1, I will give it a try. I installed the latest 2.0 package - 2.0(5f). Below is the show version, and show interface. MDS model is 9222i with NX-OS 5.2. It works well with all my other FIs running firmware 2.0 and connected with SAN Port-Channel. The problem is only with that new FI that just came in, and the only difference I see with my old FI is the BIOS version 3.6. I eliminated all other problems - moved cables around, used different MDS ports.
The problem is only with SAN Port-Channel. Individual FC interfaces register with NPIV just fine.
dc101-B(nxos)# show interface e1/1
Ethernet1/1 is down (Link not connected)
  Hardware: 1000/10000 Ethernet, address: 002a.6a3c.1d28 (bia 002a.6a3c.1d28)
  Description: S: Server
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  auto-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped never
  30 seconds input rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 input packets  0 bytes
    0 jumbo packets  0 storm suppression bytes
0 giants      0 input error  0 short frame  0 overrun   0 underrun      0 watchd
og  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 output packets  0 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
    0 Tx pause
  0 interface resets
dc101-B(local-mgmt)# show version
System version: 2.0(5f)
dc101-B(nxos)# show version
Software
  BIOS:      version 3.6.0
  loader:    version N/A
  kickstart: version 5.0(3)N2(2.05f)
  system:    version 5.0(3)N2(2.05f)
  power-seq: Module 1: version v2.0
mds1(config-if)# show version
Software
  BIOS:      version 1.0.12
  loader:    version N/A
  kickstart: version 5.2(2d)
  system:    version 5.2(2d)
Hi Araranen,
There is no need to upgrade the firmware to 2.1 this won't resolve the issue. From What I can tell this is a problem with your MDS as it doesn't recognizes the OUI of the new UCS fabric interconnect (see defect below)
Add N7K OUIs to liboui's list of recognized Cisco OUIs
https://tools.cisco.com/bugsearch/bug/CSCtr01652
also
Add MAC OUI "002a6a", "8c604f", "00defb" for 5k/UCS-FI
https://tools.cisco.com/bugsearch/bug/CSCty04686
The fix to this problem is to upgrade the software on the MDS to at least (version 5.2(8)) or later where this OUI was added to the MDS file system.
Please rate all useful posts
Hi Manuel,
you are the man. My problem was solved after upgrading mds to 5.2.8c. Thank you very much for the help.
mds1# show version
Software
  loader:    version N/A
  kickstart: version 5.2(8c)
  system:    version 5.2(8c)
  BIOS compile time:       09/10/07
  kickstart image file is: bootflash:///m9200-s2ek9-kickstart-mz.5.2.8c.bin
  kickstart compile time:  12/25/2020 12:00:00 [10/23/2013 06:42:57]
  system image file is:    bootflash:///m9200-s2ek9-mz.5.2.8c.bin
dc101-B(nxos)# show interface san-port-channel 200
san-port-channel 200 is trunking
    Hardware is Fibre Channel
    Port WWN is 24:c8:00:2a:6a:3c:1d:40
    Admin port mode is NP, trunk mode is on
    snmp link state traps are enabled
    Port mode is TNP
    Port vsan is 1
    Speed is 8 Gbps
    Trunk vsans (admin allowed and active) (1,200)
    Trunk vsans (up)                       (200)
    Trunk vsans (isolated)                 (1)
    Trunk vsans (initializing)             ()
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      845 frames input, 46964 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      1451 frames output, 211896 bytes
      31 input OLS, 31 LRR, 65 NOS, 0 loop inits
      88 output OLS, 94 LRR, 117 NOS, 0 loop inits
    last clearing of "show interface" counters never
    Member[1] : fc1/9
    Member[2] : fc1/10
    Interface last changed at Mon Jan 27 17:29:23 2014
I am glad this worked for you!!
