Firmware Management and Deleting Images/Packages
I was trying to delete some older firmware packages and was wondering if anyone had an easier way to remove the associated images. If you simply remove a package and the image is still there you get all sorts of Major warnings (image-deleted).
It would be much easier if you delete an old package ie. ucs-k9-bundle-b-series.2.0.4b.B.bin that is automatically deletes it's related Image so these errors don't appear, especially if you have upgraded a few times.
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-manager/110475-ucs-firmware-management-00.html
Everyone's tags (1)
VIP Red
Himy 2cI have never used the
my 2c
I have never used the feature to remove individual images out of a package ! why ?
The referenced paper uses this feature; I don't know anybody using it ?
Removing packages will reclaim space, and can only be done, if there are no more any references to images !
Exactly, I want to first remove the references so I can then delete the older packages. If not, I am left with annoying error messages referring to the deleted package...
86
