high memory utilization for fabric interconnect 6140
Hi all,
we have 2 fabric interconnect which runs as HA pair. One fabric interconnect of cluster can see high memory utilization 95% (the other is better and mem utilization is 70%)
Fabric-A(local-mgmt)# show processes
Cpu(s):  2.8% us, 16.4% sy,  0.8% ni, 79.4% id,  0.0% wa,  0.0% hi,  0.6% si
Mem:   3504756k total,  3373008k used,   131748k free,   119472k buffers
Swap:        0k total,        0k used,        0k free,  2240656k cached
when issue "shwo process" command, we see the following:
  PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
4263 root      16   0 94708 7664 5152 S 11.4  0.2   3694:43 /isan/bin/pfm
4368 root      15   0 73764 4108 2712 S  5.7  0.1   3568:00 /isan/bin/fcpc
2833 root      15   0 80400 4660 3156 S  0.0  0.1   3:30.40 /isan/sbin/sysmgr -V
4258 root      16   0  2340  836  680 S  0.0  0.0   0:00.09 /isan/sbin/xinetd -syslog local7 -loop 250 -stayalive -reuse -dontfork
4260 root      15   0 86444 9856 4020 R  0.0  0.3  15:01.63 /isan/sbin/syslogd -n -m 0 -r
4261 root      16   0 72648 3092 2012 S  0.0  0.1   0:00.01 /isan/bin/sdwrapd
4262 root      17   1  1820  540  460 S  0.0  0.0   0:00.03 /usr/sbin/in.tftpd --verbosity 2 -l -c -s /bootflash
4293 root      16   0 76948 4056 2496 S  0.0  0.1   0:02.42 /isan/bin/vshd
4294 root      16   0  134m 7504 4380 S  0.0  0.2   0:04.06 /isan/bin/routing-sw/smm -f /isan/etc/routing-sw/smm_shm.cfg
4295 root      16   0 72928 3520 2188 S  0.0  0.1   0:13.20 /isan/bin/ssnmgr
4296 root      16   0 70824 2208 1612 S  0.0  0.1   0:11.28 /isan/bin/psshelper -s 219
4297 root      16   0  2324 1272  980 S  0.0  0.0   0:00.30 /isan/bin/lmgrd -l +/dev/null -z -c /isan/etc/licenses.base:/isan/etc/licenses
4298 root      16   0 71328 2852 2164 S  0.0  0.1   0:06.18 /isan/bin/licmgr
4299 root      16   0 76180 2788 2088 S  0.0  0.1   0:00.06 /isan/bin/fs_daemon
4300 root      16   0 70036 1948 1484 S  0.0  0.1   0:03.37 /isan/bin/feature_mgr
4301 root      16   0 79804 3764 2880 S  0.0  0.1   0:05.32 /isan/sbin/fcfwd -s
4302 root      16   0 69996 1640 1296 S  0.0  0.0   0:00.01 /isan/bin/confcheck
4303 root      16   0 72708 3220 2128 S  0.0  0.1   0:06.71 /isan/bin/capability
4304 root      16   0 70824 2204 1608 S  0.0  0.1   0:10.81 /isan/bin/psshelper -s 398
4312 root      16   0  2656 1552 1128 S  0.0  0.0   0:01.52 cisco -T localhost 10.1 3 -c /isan/etc/licenses.base:/isan/etc/licenses -lmgrd_port 6978 --lmgrd_start 4f4ed34c
4315 root      16   0  121m  45m  34m S  0.0  1.3   0:18.93 /isan/bin/routing-sw/clis -cli /isan/etc/routing-sw/cli
4328 root      16   0  1412  452  392 S  0.0  0.0   0:00.07 /sbin/klogd -2 -x
4345 root      16   0 97576 8008 4460 S  0.0  0.2   0:12.55 /isan/bin/zschk
4346 root      16   0 70188 1688 1324 S  0.0  0.0   0:15.33 /isan/bin/xmlma
4347 root      16   0 71032 2648 1676 S  0.0  0.1   2:05.46 /isan/bin/wwn_manager 2
4348 root      16   0 75384 6224 2748 S  0.0  0.2   0:12.57 /isan/bin/vmm
4349 root      16   0 74512 3516 2584 S  0.0  0.1   0:10.11 /isan/bin/vdc_mgr
4350 root      16   0 77580 3536 2688 S  0.0  0.1   0:06.70 /isan/bin/ttyd
4351 root      16   0 68720 1484  924 S  0.0  0.0   1:35.94 /isan/bin/sysinfo
4352 root      -2   0 81296 2444 1712 S  0.0  0.1 250:18.21 /isan/bin/sensor
4354 root      16   0 71364 2488 1824 S  0.0  0.1   0:00.19 /isan/bin/res_mgr
4356 root      16   0 72924 3380 2200 S  0.0  0.1   0:00.28 /isan/bin/plugin
4357 root      16   0 82260 6520 3756 S  0.0  0.2   0:28.71 /isan/bin/pltfm_config
4358 root      16   0 68884 1396 1092 S  0.0  0.0   0:07.21 /isan/bin/plog_sup
4359 root      16   0 82936 2492 1908 S  0.0  0.1   0:01.23 /isan/bin/obfl_sup
4360 root      16   0  136m  12m 7264 S  0.0  0.4   0:16.26 /isan/bin/nppm
4361 root      15   0 91556 8868 4344 S  0.0  0.3   0:10.51 /isan/bin/routing-sw/npacl
4362 root      16   0 85040 4080 2624 S  0.0  0.1   0:12.37 /isan/bin/nohms
4363 root      16   0 72480 3108 2032 S  0.0  0.1   0:05.00 /isan/bin/mvsh
4364 root      16   0 72908 3504 2248 S  0.0  0.1   0:12.31 /isan/bin/msp
4365 root      16   0 80604 1700 1328 S  0.0  0.0   0:09.17 /isan/bin/ledmgr
4366 root      16   0 88360  12m 5192 S  0.0  0.4   0:49.82 /isan/bin/ifmgr
4367 root      -2   0  144m 9276 3072 S  0.0  0.3 962:01.67 /isan/bin/gatosusd -M L -L 63
4369 root      16   0 72712 3188 2080 S  0.0  0.1   7:39.90 /isan/bin/evmc
4370 root      16   0 93732 6500 3996 S  0.0  0.2   0:12.35 /isan/bin/ethpc
4371 root      16   0 93676  15m 3904 S  0.0  0.4   0:44.88 /isan/bin/eth_dstats
4372 root      16   0 93500  11m 5148 S  0.0  0.3   0:17.21 /isan/bin/enm
4373 root      15   0 77232 3412 2608 S  0.0  0.1   0:00.06 /isan/bin/core_daemon
4374 root      16   0 70536 1920 1468 S  0.0  0.1   0:06.91 /isan/bin/bootvar
4375 root      16   0 70948 1664 1256 S  0.0  0.0   0:03.35 /isan/bin/bios_daemon
4376 root      -2   0 88648 3804 1944 S  0.0  0.1   0:08.57 /isan/bin/athertonusd -M L -L 63
4377 root      16   0 81304 5124 3772 S  0.0  0.1   0:00.87 /isan/bin/ascii_cfg_server
4378 root      -2   0 87732 3296 2228 S  0.0  0.1   0:25.61 /isan/bin/altos
4379 root      16   0 72436 2968 2112 S  0.0  0.1   0:19.04 /isan/bin/securityd
4380 root      16   0 81428 4748 3468 S  0.0  0.1   0:10.98 /isan/bin/cert_enrolld
4381 root      16   0 73104 3724 2472 S  0.0  0.1   0:11.49 /isan/bin/cssmgr
4382 root      16   0 73116 3500 2096 S  0.0  0.1   0:20.67 /isan/bin/aaad
4396 root      16   0 84528 9148 3768 S  0.0  0.3   0:03.90 /isan/bin/routing-sw/l3vm
4397 root      16   0 93652  14m 5080 S  0.0  0.4   0:30.20 /isan/bin/eth_span
4398 root      15   0  101m  26m  21m S  0.0  0.8   0:07.09 /isan/bin/routing-sw/u6rib
4399 root      15   0  123m  48m  41m S  0.0  1.4   1:54.94 /isan/bin/routing-sw/urib
4400 root      16   0  1424  392  340 S  0.0  0.0   0:29.69 /isan/bin/ptpd -p -b vlan4044
4403 root      16   0  112m  14m  12m S  0.0  0.4   0:12.89 /isan/bin/vms
4404 root      15   0  132m  42m 9.8m S  0.0  1.3   5:03.41 /isan/bin/fwm
4405 root      16   0 97732 7724 4956 S  0.0  0.2   0:15.27 /isan/bin/qd
4406 root      16   0 97080 7044 4200 S  0.0  0.2   1651:18 /isan/bin/stats_client
4408 root      16   0 90640  12m 5076 S  0.0  0.4   0:26.66 /isan/bin/vlan_mgr
4418 root      16   0  1480  532  428 S  0.0  0.0   0:16.88 /isan/bin/pmon -i -f /isan/etc/pmon.conf
4419 root      16   0 88316 9.8m 5768 S  0.0  0.3   0:08.57 /isan/bin/aclmgr
4420 root      16   0 98.7m  10m 6088 S  0.0  0.3   1:53.94 /isan/bin/afm
4421 root      16   0 87108 9428 6316 S  0.0  0.3   1:19.26 /isan/bin/eth_pcm
4428 root      16   0 82316 5224 3532 S  0.0  0.1   0:11.10 /isan/bin/ldapd
4430 root      15   0  144m  12m 3788 S  0.0  0.4   0:27.53 /isan/bin/routing-sw/am
4431 root      15   0  169m  33m  21m S  0.0  1.0  71:47.48 /isan/bin/snmpd -f -s udp:161 tcp:161 -e readonly -n linux_ip
4437 root      16   0 93280  14m 8784 S  0.0  0.4   0:11.40 /isan/bin/ipqosmgr
4438 root      16   0  113m  37m 7524 S  0.0  1.1  50:32.36 /isan/bin/ethpm
4450 root      26  10 78556 4468 3296 S  0.0  0.1   0:11.56 /isan/bin/callhome
4451 root      16   0 82120 5648 3976 S  0.0  0.2   1:02.47 /isan/bin/vsan_mgr
4453 root      16   0 67956  868  720 S  0.0  0.0   0:00.01 /isan/bin/core_client -t
4488 root      16   0 73020 3868 2608 S  0.0  0.1   0:14.47 /isan/bin/epp
4489 root      15   0 75116 4256 2924 S  0.0  0.1   0:25.99 /isan/bin/dom_mgr
4490 root      16   0 92564  13m 7572 S  0.0  0.4   7:49.23 /isan/bin/port_mgr
4491 root      16   0 84660 8292 3816 S  0.0  0.2   0:00.32 /isan/bin/rib
4492 root      16   0 82672 7892 5544 S  0.0  0.2   1:42.97 /isan/bin/pcm
4523 root      20   0  122m 9692 4168 S  0.0  0.3   0:11.35 /isan/bin/routing-sw/arp
4524 root      15   0  105m  11m 4960 S  0.0  0.3   0:10.91 /isan/bin/routing-sw/icmpv6
4525 root      20   0  213m  56m 7272 S  0.0  1.6  87:30.72 /isan/bin/routing-sw/netstack /isan/etc/routing-sw/pm.cfg
4568 root      16   0  119m 5444 3756 S  0.0  0.2   0:14.87 /isan/bin/radiusd
4569 root      15   0  102m  22m  19m S  0.0  0.7  12:08.24 /isan/bin/cfs
4570 root      15   0  129m  14m 6296 S  0.0  0.4   5:30.94 /isan/bin/routing-sw/igmp
4571 root      16   0 68300 1020  820 S  0.0  0.0   0:00.00 /isan/bin/routing-sw/netstack_dummy 267
4572 root      16   0 68300 1020  820 S  0.0  0.0   0:00.01 /isan/bin/routing-sw/netstack_dummy 269
4573 root       0 -20  119m 5636 3936 S  0.0  0.2   0:01.51 /isan/bin/ntp 5
4574 root      16   0  137m 6004 4092 S  0.0  0.2   0:12.23 /isan/bin/otm
4575 root      16   0 68300 1020  820 S  0.0  0.0   0:00.01 /isan/bin/routing-sw/netstack_dummy 263
4576 root      16   0 68300 1020  820 S  0.0  0.0   0:00.01 /isan/bin/routing-sw/netstack_dummy 271
4585 root      16   0 86484  10m 5812 S  0.0  0.3   0:04.91 /isan/bin/npm
4587 root      16   0  123m 6720 4748 S  0.0  0.2   0:36.47 /isan/bin/cdpd
4588 root      15   0 94184  17m 5492 S  0.0  0.5  76:51.48 /isan/bin/satmgr
4589 root      15   0 90668  14m 4832 S  0.0  0.4   0:53.38 /isan/bin/lldp
4590 root      15   0 94212  16m  11m S  0.0  0.5   3:00.82 /isan/bin/stp
4591 root      15   0 78740 4120 2972 S  0.0  0.1   0:00.03 /isan/bin/routing-sw/dcos-xinetd -syslog local7 -loop 250 -stayalive -reuse -dontfork -f /etc/dcos-xinetd.conf -pidf
4592 root       0 -20  3656 3656 2712 S  0.0  0.1   0:08.78 /isan/bin/ntpd -g -f /mnt/pss/ntp.drift -A -n
4651 root      16   0 92580  14m 5820 S  0.0  0.4   0:32.83 /isan/bin/sifmgr
4684 root      11  -5 44868  22m  15m S  0.0  0.7   8:19.72 svc_sam_controller --x /opt/db/sam.config
4685 root      21   3  278m 138m  38m S  0.0  4.1 270:35.75 svc_sam_dme --x
4689 root      18   3  175m  35m  23m S  0.0  1.0   1:43.15 svc_sam_dcosAG --x
4700 root      19   3 87264  37m  18m S  0.0  1.1  65:22.59 svc_sam_bladeAG --x
4702 root      18   3  173m  37m  25m S  0.0  1.1   0:56.74 svc_sam_portAG --x
4715 root      24   4  173m  36m  23m S  0.0  1.1 279:54.92 svc_sam_statsAG --x
4720 root      19   3 50880  23m  16m S  0.0  0.7   0:22.83 svc_sam_hostagentAG --x
4721 root      19   3 66024  29m  16m S  0.0  0.9  15:29.65 svc_sam_nicAG --x
4726 root      19   3 46836  24m  16m S  0.0  0.7   0:14.13 svc_sam_licenseAG --x
4740 root      23   3  171m  31m  21m S  0.0  0.9   0:13.11 svc_sam_extvmmAG --x
4742 root      19   3  2252 1128  924 S  0.0  0.0   5:00.53 /bin/sh /isan/bin/httpd.sh --x
4747 root      19   3  192m  56m  36m S  0.0  1.7   0:17.15 svc_sam_sessionmgrAG --x
4752 root      19   3  143m  27m  19m S  0.0  0.8   0:02.27 svc_sam_pamProxy --x vlan4044
4753 root      19   3 10156  836  632 S  0.0  0.0   0:00.00 sfcbd -c /isan/etc/dmtf/sblim-sfcb-1.2.4-100407/sfcb.cfg
4760 root      15   0  4860 2884 1108 S  0.0  0.1   3:30.41 dhcpd -f -cf /isan/etc/dhcpd.conf -wf /opt/db/sam.config -lf /isan/etc/dhcpd.leases vlan4047 vlan4044
4763 root      20   3 10156  740  552 S  0.0  0.0   0:00.00 sfcbd -c /isan/etc/dmtf/sblim-sfcb-1.2.4-100407/sfcb.cfg
4764 root      19   3 14140 4804  712 S  0.0  0.1   0:00.01 sfcbd -c /isan/etc/dmtf/sblim-sfcb-1.2.4-100407/sfcb.cfg
4765 root      21   3 44632  22m  15m S  0.0  0.7   0:11.54 svc_sam_rsdAG --x
4798 root      20   3 10188  932  720 S  0.0  0.0   0:00.00 sfcbd -c /isan/etc/dmtf/sblim-sfcb-1.2.4-100407/sfcb.cfg
5916 root      16   0 84304 8784 5060 S  0.0  0.3   0:02.31 /isan/bin/pvlan
5917 root      16   0 82728 6016 3912 S  0.0  0.2   0:31.51 /isan/bin/tacacsd
5918 root      16   0 91144  11m 5388 S  0.0  0.3   0:24.35 /isan/bin/eth_port_sec
5922 root      16   0 87476 9516 5772 S  0.0  0.3   0:33.99 /isan/bin/fcoe_mgr
5923 root      15   0 85284 9300 5116 S  0.0  0.3   4:53.83 /isan/bin/lacp
12685 root      16   0  1496  536  460 S  0.0  0.0   0:00.00 /sbin/getty -L ttyS0
14971 root      19   3  2236  676  532 S  0.0  0.0   0:00.00 /isan/bin/rotatelogs /var/sysmgr/sam_logs/error_log 2M
3481 root      15   0  6416 3044 2380 S  0.0  0.1   0:00.17 sshd:
user1@pts/5
3523 root      16   0 87808  54m  33m S  0.0  1.6   0:00.54 /isan/bin/ucssh --ucs-mgmt -p user1
4128 root      15   0 87808  53m  33m S  0.0  1.6   0:00.45 /isan/bin/ucssh --ucs-local-mgmt -t 30 -p user1
4511 root      16   0 87812  53m  33m S  0.0  1.6   0:00.00 /isan/bin/ucssh --ucs-local-mgmt -t 30 -p user1
I added all above mem percentage and the sum is about 47%. I can't find where are 48% mem utiization from?
Any help and suggestion is highly appreciated.
David
David,
It could be normal as Linux attempts to use most of the memory. Notice the value for buffers / cached field.
You can find lot of excellent articles about linux memory management and buffers / cache mechanism.
Do we have the output from FI taken at regular intervals of time ?
Padma
Re: high memory utilization for fabric interconnect 6140
The high mem utilization has been there for more 4 days. Always high. (BTW, i just logged a case with cisco TAC, Thank u very much for your help!)
1522
