How can i configure fence_cisco_ucs with redhat cluster suite
bentech4u
HI
How can i configure fence_cisco_ucs with redhat cluster suite.
i was trying to configure fencing aganet with red ahat cluster suite
i issued command
#  /usr/sbin/fence_vmware_soap -a 172.22.90.61 -l admin -p duc2Cisco -o reboot
then i got below error:
Failed: You have to enter plug number
Please use '-h' for usage
what is this plug number and from where can i get this plug number.?
I am new to this Cisco UCS, becuase this hardware is provided my some other team and i am the one installing Red Hat cluster suite. I requested fencing agent configuration with Cisco, and that guy dosen't know what is fencing..
please help me, because of this issue, production got delayed
regards,
Ben
6 Replies 6
Brian Morrissey
Hi Ben,
Are you using fence_cisco_ucs or fence_vmware_soap?  For fence_cisco_ucs I believe the plug number is the name of the service profile attached to the server.
HI
thanks for your replay
actually i tried both fence_cisco_ucs and fence_vmware_soap. which one is used for fencing configuration..
i think both method asking for plug number.
i have access to UCS control panel. from where can i get these service or plug number.
i tried te below, i don't i took one profile name from UCS cpanel and checked:
/usr/sbin/fence_cisco_ucs -a 172.22.90.61 -l admin -p duc2Cisco -n org-root/ls-cgceccprd1 -o reboot
Traceback (most recent call last):
  File "/usr/sbin/fence_cisco_ucs", line 147, in
    main()
  File "/usr/sbin/fence_cisco_ucs", line 120, in main
    res = send_command(options, "")
  File "/usr/sbin/fence_cisco_ucs", line 92, in send_command
    c.perform()
pycurl.error: (28, 'connect() timed out!')
that also got error
Thanks & regards,
Ben
bentech4u
please anyone tell me how can i configure fencing with fence_cisco_ucs.
from where can i get the Ip and all details.. i sthat same IP of KVM we need to give or any other IP
can i know this KVM IP is only for communicating between ucs central and server.?
regards,
Ben
Hi Ben,
Which IPs have you tried?  I think it is the ucs manager ip that you need to use.  Are the ports open between the rhel blade and ucsm?  80/443 tcp depending on your setup.
ports are opened between servers
ucs manager IP with wat all are the details i need to provide
Ben
Hi Ben,
Could try adding ssl and removing the org name like this, sounds like a connectivity issue
fence_cisco_ucs -a 172.22.90.61 -l admin -p duc2Cisco -z -n cgceccprd1 -o reboot
