Community Member
How get the system clock synced?
I messed up the clock sync, because I specified ntp-clock. At the moment the clock is 10 min faster on FI-B (Show clock). I assume this is why I no longer can log into UCSM?
I have rebooted both the FIs, but the clock is still different on the FI-B.
Doing this, does not help:
UCS-A# scope systemUCS-A /system # scope servicesUCS-A /system/services # set clock apr 14 2010 15 27 00UCS-A /system/services #
Message was edited by: Atle Dale at 13:36
1 ACCEPTED SOLUTION
Silver
Hi Atle,
go ahead and open up a TAC case and we'll take a look at it from there.
./Abhinav
Community Member
this is status now. I hope this is not going to cause problems later, or is causing the other problems I do have:
FI6120XP-B(local-mgmt)# show clock
Thu Aug  9 13:41:18 CEST 2012
Thu Aug  9 13:43:06 CEST 2012
FI6120XP-A /system/services # end
FI6120XP-A# show clock
Thu Aug  9 14:34:05 CEST 2012
Silver
Hi Atle,
./Abhinav
Community Member
Re: How get the system clock synced?
Unfortunately, my account is not set up for this yet. But I really want to start upgrading firmware today. Can I start with this still?
Community Member
status: I enabled NTP again and this almost solved the problem. The time is now correct on FI-A in the right timezone, but the the time is 10 min too fast on FI-B.
Community Member
this can be closed orset as "Answered". I coul dnot delete it or mark it as "Answered" myself. The reason for this problem was that the FI-B was connected with mgmt1 port.
444
