how many fan of UCS-C210-M2 server
Hi All,
Could anybody confirm that number of the UCS-C210-M2 server?
We have 4 UCS-C210-M2 server,
One of the server have 10 fan, and 4 in the critical status
but the others only have 6 fan.
Is this could be a wrong alarm or should we rma the fan?
thanks before.
ATommy
Silver
You are hitting a known issu eon the C210 server:
CSCtr11881    UCS C210 FAN4 FAN5 TACH sensors have status Critical and speed 0
Workaround: reset the CIMC and that should take care of this fault.
Soultion: Update the firmware to any of the latest 1.4 release.
Thanks!
Abhinav
Hi Abbharga,
Thanks for the reply.
I'll try to reset the CIMC first and hopefully will take care of this fault.
ATommy
588
