How QoS works in UCS
Hi All,
I configured QoS in UCS and want to know how it actually works
Once I configured system classes form GUI following is the configuration found in NXOS
policy-map type queuing system_q_in_policy
  class type queuing class-platinum
    bandwidth percent 32
  class type queuing class-silver
    bandwidth percent 25
  class type queuing class-bronze
    bandwidth percent 22
  class type queuing class-fcoe
    bandwidth percent 18
  class type queuing class-default
    bandwidth percent 3
policy-map type queuing system_q_out_policy
    bandwidth percent 3
Then I created a qos policy called "vm-data-platinum" with rate=1000kbps and
burst=10240bytes using platinum class.
Following is the configuration found in nxos.
policy-map type queuing org-root/ep-qos-vm-data-platinum
    bandwidth percent 50
    shape 1000 kbps 10240
Question1: class-default bandwith in system_q_in_poliy and system_q_out_policy
                is 3, but in vm-data-platinum it is 50. So how this works?
                I initially thought that even in vm-data-platinum the bandwidth percent of class-default
                should be 3.
Question2: In ep-qos-vm-data-platinum policy-map there is no entry to indicate that this
                 policy uses class platinum and its bandwidth?
                 So how this works?
Jagath
493
