How set native vlan on a VM in vSphere when using the 1000V?
Using the vSphere Distr Switch, we set native VLAN per VM by setting the VLAN d to 0.
How do we set the native VLAN for a VM if the VM is connected to a 1000V? I heard we no longer can use VLAN ID 0?
  • Unified Computing
Everyone's tags (6)
1 ACCEPTED SOLUTION
Re: How set native vlan on a VM in vSphere when using the 1000V?
Same way you would on any Cisco switch.
Add this command to your Uplink port profile:
switchport trunk native vlan X
Keep in mind there is no VLAN 0.  VLAN "0" is just how vmware designates the untagged VLAN.  Valid ranges are 1-4095 according to the standard.
Robert
Robert
ok, I think what confuses me is that this changed with the 1000V. Correct? Before this was configured in vSphere GUI and we set the VLAN to 0 for the network to be untagged. With the 1000V all the network config was moved to the 1000V.
807
