Community Member
how to cancel pending activities in ucsm
how do I cancel a pending task in ucsm thats is waiting for me to ack. I just want to cancel the task.
1 ACCEPTED SOLUTION
As Keny outlined, you need to
As Keny outlined, you need to revert whatever change that triggered the pending activity in order to clear it. Else, evacuate the host and acknowledge the reboot.
Community Member
HelloCheck this linkhttps:/
Hello
Check this link
https://cisco-images.test.edgekey.net/c/en/us/td/docs/unified_computing/ucs/sw/gui/config/guide/2-2/b_UCSM_GUI_Configuration_Guide_2_2.pdf .
hope this pdf help you better.
You need to revert the
You need to revert the changes for those "Pending activities" to be cleared.
-Kenny
Hello Keny how do you change
Hello Keny how do you change the pending activities to cleared ?
661
