how to change ucs hba queue depth for esxi 5.1
hi
how do I change the queue depth for an esxi host in 5.1 for ucs b200?
In esxi
I type esxcli system module parameters -m list
it shows
~ # esxcli system module parameters  list -m  fnic
Name                     Type  Value  Description
fnic_fc_trace_max_pages  uint         Total allocated memory pages for fc trace buffer
fnic_max_qdepth          uint         Queue depth to report for each LUN
fnic_trace_max_pages     uint         Total allocated memory pages for fnic trace buffer
heap_initial             int          Initial heap size allocated for the driver.
heap_max                 int          Maximum attainable heap size for the driver.
skb_mpool_initial        int          Driver's minimum private socket buffer memory pool size.
skb_mpool_max            int          Maximum attainable private socket buffer memory pool size for the driver.
how do I change it and what is the recommended queue depth?
1 ACCEPTED SOLUTION
VIP Green
Has been covered before, see
Has been covered before, see e.g.
https://supportforums.cisco.com/discussion/12215126/queue-depth-execution-throttle
https://supportforums.cisco.com/discussion/11744776/ucs-hba-queue-depth-vmware-esxi-51
VIP Green
hi does it require a reboot
hi
does it require a reboot for this?
is it recommeded to change
is it recommeded to change the queue depth to 128 or higher? what is the best practice? default is 32 for esxi 5.1
1171
