how to clear Faults on UCSM 1.4(3q)
I'm running a 1.4(3q) platform and i'd would like to clear all the faults displayed on the UCSM.
How can i do that ?
i would like to delete faults because in some case, it very old faults.
All the faults are Acknoledged but i can't clear it.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Silver
Can you capture a screen shot of the fault or the faults details from the CLI and attach it there.
as well as a capture of the backup jobs.
One quick thing you can try, if its for a back job which is still present in the UCSM: try to delete the job and this should clear the fault. You can then re-create the job once the fault is cleared.
./Abhinav
Silver
Hi florent,
In UCSM the faults are not cleared untill the condition causing those faults are not cleared. I would advise you to look at the reason for the faults and resolve those which will clear the faults.
Thanks!
./abhinav
Ok, thanks for responding.
i'm ok with your answer but some faults are not cleared.
As a example, there is a critical fault concerning a backup that is not perform.
Fault Code:F999723
But now the backup is working correctly.
thanks
Florent
Silver
./Abhinav
Thanks Abhinav,
The fault has been cleared, when i deleted the backup jobs.
So i thinks i must parse all the faults.
Thanks a lot.
Florent
Silver
Good to know it worked for you
./abhinav
1317
