How to do UCS C-Series Automatic alert mechanism ??
EX: NIC  & CNA card (P81E)  & HBA CARD .....failure Adapter .
Automatic alert to the administrator ??  (mail)  Related software or setting can refer to?
Silver
Hi Fu,
You can look at setting up the SNMP for monitoring the server and the system can send you the alerts.
thanks!
./Abhinav
Re: How to do UCS C-Series Automatic alert mechanism ??
snmp set in cimc ?? or Cisco UCS C-Series Manager MIB Support List
ftp://ftp.cisco.com/pub/mibs/supportlists/ucs/ucs-C-supportlist.html#MIBs_Supported_for_Cisco_UCS_Cseries_141
Cisco Unified Computing System (UCS) C-Series CIMC SNMP Agent software
Fu,
I would recommend setting up Call Home...
https://supportforums.cisco.com/videos/1471
I hope I did not misunderstand your question.
-Kenny
Setup call home based on your need (Critical, Warning etc..). Call home will generate automatic emails for you and can also alert Cisco TAC.
You can set up Call Home on the server.
Make sure the server is integrated with the UCSM.
Check for further details:
https://supportforums.cisco.com/docs/DOC-19087
David
768
