01-06-2014 10:52 PM - edited 03-01-2019 11:26 AM
Should limit a vNic to use maximum of 5GB/s..
Solved! Go to Solution.
01-08-2014 01:05 AM
You don't really specify the line rate. Line-rate is the speed which will cause entrie available BW to be used.
To answer the underlying question, when you lower the rate, you specify shaping value and burst.
Shaping is discussed for example here:
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_q_and_a_item09186a00800cdfab.shtml#policing
Example
bdsol-6248-06-A(nxos)# show run | section Gold
policy-map type queuing org-root/ep-qos-Gold_QoS
class type queuing class-default
bandwidth percent 100
shape 5000000 kbps 65000
and when using line rate.
bdsol-6248-06-A(nxos)# show run | section Platinium
policy-map type queuing org-root/ep-qos-Platinium_5124
shape 10000000 kbps 5124
Related output from my USC in the lab.
01-07-2014 12:02 AM
http://www.cisco.com/image/gif/paws/110509/ucs-qos-04.gif
source:
http://www.cisco.com/en/US/products/ps10278/products_configuration_example09186a0080ae54ca.shtml
and
01-07-2014 10:22 PM
Thank you, Marcin.
Quick question -
Once you set the line rate as 5GB/s, would that be a hard limit on that PCIe device? or can the device get more than the specified bandwidth?
01-08-2014 01:05 AM
Example
01-09-2014 03:05 AM
Thank you, Marcin.
