How to set RAID 1 in C200-M1
leninvs2502
Hi, does anybody know how to set RAID1 in UCS C200-M1?
Thanks in advance
Lenin
Go into the BIOS of the server and disable quiet boot.  Once this is done reboot the server and enter the LSI config during the boot process.  I think it is a ctrl-S to get into the LSI config.  Once you are in the LSI config you can set the RAID level for the drives.
ccietrainee1
Do let me know the type of RAID controller being used.
Ram
Thanks for replying ccietrainee1, I've got a C200-M1 with two local disks, 140GB each one, and I want to set RAID 1 between them, how can I see the type of RAID controller in the server or do I have to install it?
I really appreciate your help
Thanks a lot jdrurycisco,
I'm using ESX 4.0 Update1, Do I have to reinstall it after change to RAID 1 or it's not necessary?
Very grateful
Lenin
