install Nexus 1000 v over existing architecture
I have got a architecture VMware :
- 2 esxi
- 1 Vcenter server
- Dvswitch configured
Can we install  Nexus 1000 v VEM over dvswitch ?
Is it possible to have dvswitch and Nexus 1000V (VEM) together on the same architecture?
André
Silver
Hi Andre,
You can surely have N1K + vDS on the same host.
However the VEM uses its own uplink interface and they cannot be on the vSwitch or the vDS. what does that mean, you will need seprate vmnic / interface which will be used by the n1k vem on the esxi host.
./Abhinav
Abbharqa,
Now, I don't know very well this architecture, VM/Nexus.
No problem for uplink interface, I have got lot of interfaces  !!
It's for easly migrated the VMs from Vm dvswitch to nexus DVS.
André
Silver
Andre,
Here is a deployment guide which should help you.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9902/guide_c07-556626.html
in addtion here is the URL to the content about n1k on the cisco site. There are a lot of videos as well which can help you
http://www.cisco.com/en/US/products/ps9902/prod_installation_guides_list.html
./Abhinav
I have realised the deployment of my nexus 1000v.
Can I connected two VEMs by etherchannel to switch of datacenter ?
VEM Esxi A  > Vnic 7                                              SwA Int  Fa0/1
                                     >>>>>>>Etherchanel>>>>
VEM Esxi A  > Vnic 9                                              SwA Int  Fa0/2
VEM Esxi B  > Vnic 7                                                SwA Int  Fa0/3
                                    >>>>>>>Etherchanel>>>>>
VEM Esxi B  > Vnic 9                                                SwA Int  Fa0/4
On Sw A, All interfaces would in the same etherchannel.
I don't make it,  I afraid a loop !!
André
Hi Andre,
You would have different portchannels configured for each esx host.  So on SwA you would have 1 portchannel for EsxiA nics only and another seperate portchannel for EsxiB nics only.
I have a another problem.
I don't remove a VEM from ESXi 5.0.
I did  :
~ # vem-remove
Please remove host from DV switch or run hotswap script.
~ # hotswap.sh -u
The following switch is of type cisco_nexus_1000v: DvsPortset-2
0x 2. 0. 0. 0
Starting time: Mon Jul  2 14:41:24 UTC 2012
stopDpa
Unload N1k switch modules
Warning: /dev/char/vmkdriver/stun not found
Unload of N1k modules done.
~ # /usr/lib/vmware/bin/net-dvs -l | grep cisco_nexus
switch 22 f6 27 50 ff b6 46 c1-85 47 f8 ff c6 7d 5f 69 (cisco_nexus_1000v)
~ # net-dvs -d -n "22 f6 27 50 ff b6 46 c1-85 47 f8 ff c6 7d 5f 69"
ioctl failed: Device or resource busy
Operation failed: status = 0xbad0004
~ # esxcfg-vswitch -l
Switch Name      Num Ports   Used Ports  Configured Ports  MTU     Uplinks
vSwitch0         128         4           128               1500    vmnic0
  PortGroup Name        VLAN ID  Used Ports  Uplinks
  n1kv-control          330      0           vmnic0
  n1kv-mgmt             1        0           vmnic0
  n1kv-packet           331      0           vmnic0
  VM Network            0        0           vmnic0
  VMkernel              0        1           vmnic0
  Management Network    0        1           vmnic0
DVS Name         Num Ports   Used Ports  Configured Ports  MTU     Uplinks
n1kv-test        256         1           256               1500
  DVPort ID           In Use      Client
  322                 0
  323                 0
  324                 0
  325                 0
  326                 0
  327                 0
  328                 0
  329                 0
  330                 0
  331                 0
  332                 0
  333                 0
  334                 0
  335                 0
  336                 0
  337                 0
  338                 0
  339                 0
  340                 0
  341                 0
  342                 0
  343                 0
  344                 0
  345                 0
  346                 0
  347                 0
  348                 0
  349                 0
  350                 0
  351                 0
  352                 0
  353                 0
dvSwitch1        256         4           256               1500    vmnic6,vmnic8
  0                   1           vmnic8
  1                   1           vmnic6
  2                   0
  136                 0
  137                 1           vCenter.eth0
  138                 0
  139                 0
How do for remove the VEM on Esxi server??
André,
Re: install Nexus 1000 v over existing architecture
Hi Andre,
To remove the host you should be able to do it from within the vsphere client once all networking has been migrated back to a vswitch.  Goto inventory->networking, select the nexus dvs, select the host tab, right click on the host and select remove from vnetwork distributed switch.
Once this is done try running vem-remove -d again.
1190
