Intel Corporation 82599EB 10-Gigabit "Receive missed errors"
I am seeing  "Receive missed errors"   when I try to send more than 1Gbps of traffic using Intel Corporation 82599EB 10-Gigabit  NIC  on UCS 220 M3 .
ESXi5.5 is installed on server with NIC driver mentioned below .  Is there any solution for this problem . It is impacting my customers performance testing.
~ # ethtool -i vmnic2
driver: ixgbe
version: 3.7.13.7.14iov-NAPI
firmware-version: 0x61b50001
bus-info: 0000:03:00.0
2 ACCEPTED SOLUTIONS
Where are you getting these
Where are you getting these error messages?
Do you already checked the cable and the peer connector?
Hi, It seems be a driver
It seems be a driver problem. Take a look on this link:
http://itnervecenter.com/content/received-missed-errors-esxcli-network-command-and-intel-10gb-nics
Regards.
Hi Richard,
Hi Richard,
                  I am seeing these error counters on ESXi5.5 Shell . Cable and peer connector is fine , I see this problem only when I send more that 1Gig of traffic this is intel 10G NIC so it should be able to handle at least close to 5G if not 10G . At the moment it is behaving like 1G.
thx
-Shashi
~ #  esxcli network nic stats get -n vmnic2
NIC statistics for vmnic2
   Packets received: 70355354200
   Packets sent: 70510201732
   Bytes received: 27508803837753
   Bytes sent: 27566735534424
   Receive packets dropped: 0
   Transmit packets dropped: 0
   Total receive errors: 0
   Receive length errors: 0
   Receive over errors: 0
   Receive CRC errors: 0
   Receive frame errors: 0
   Receive FIFO errors: 0
   Receive missed errors: 2294139  <-----
   Total transmit errors: 0
   Transmit aborted errors: 0
   Transmit carrier errors: 0
   Transmit FIFO errors: 0
   Transmit heartbeat errors: 0
   Transmit window errors: 0
Regards.
Thanks a lot Richard , Let me
Thanks a lot Richard , Let me upgrade the driver and try it out . Really appreciate your prompt response.
-Shashi
900
