07-24-2014 10:03 AM - edited 03-01-2019 11:45 AM
I noticed I have a one link linking group preference of none set on my chassis/fex disovery policy
then I noticed that under the LAN tab, under internal LAN, there is no port channel set.
When I change the policy to 1 link and port channel and reack the chassis, I see 4 ports under the port channel in internal LAN.
Is it necessary to change the policy to port channel or can i just leave it at none?
What would be the difference?
Solved! Go to Solution.
07-24-2014 11:51 AM
Best practise is to use port-channel between IOM and FI; (this requires second generation hardware for FI (62xx) and IOM (220x)
If your discovery policy is set to 1, and you ack the chassis, it will automatically create a pc of 4 links.
07-24-2014 11:51 AM
07-24-2014 01:25 PM
IF i change the policy to port channel and reack the chassis, will that affect the hosts?
07-24-2014 01:29 PM
Reack the chassis disrupts any traffic from the IOM to FI for about 20-25 seconds. No server will be rebooted; most OS can tolerate this outage of traffic; however, if you run e.g. a heavy loaded database server, it might not like it.
07-25-2014 01:22 PM
Does it support only even number of links from the iom to the FI?
Does it support 3 links per iom?
07-25-2014 11:58 PM
NO -> Link Discovery Policy can be only 1, 2, 4, 8, depending of the IOM model
see Table 7: Chassis/FEX Discovery Policy and Chassis Links
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/gui/config/guide/2-2/b_UCSM_GUI_Configuration_Guide_2_2.pdf
