06-18-2010 09:40 AM - edited 03-01-2019 09:40 AM
I just wanted to verify that I have my physical connections setup:
If I have 2 Fabric interconnects and 2 chassis, I should connect:
Chassis1-IOM1 connected to Fabric1
Chassis1-IOM2 connected to Fabric2
Chassis2-IOM1 connected to Fabric2
Chassis2-IOM2 connected to Fabric1
Is this correct? I just want to make sure I'm not supposed to connect it this way:
Chassis2-IOM1 connected to Fabric1
Chassis2-IOM2 connected to Fabric2
The Cisco high availability http://www.ciscosystemscapital.biz/en/US/products/ps10278/products_configuration_example09186a0080aef90f.shtml document doesn't specify how to connect 2 chassis. Thanks.
Thanks.
Solved! Go to Solution.
06-18-2010 10:04 AM
Hi Terence.
The first thing you need is to define is how many connection you want from the Chassis to each of the Fabric Interconnects.
IO Modules connect to either FIC A or B (not to both) - If you connect port 1 of the left IO Module to FIC A then the other ports also need to connect to it .
Then you should have all your chassis connected all the same way (ideally though you may have more bandwidth requirements in one chassis then on the other and therefore have more connections - server ports on one chassis than on the other).
The above means that if you are using only 1 server port per FIC to the chasssis you should connect each chassis like this (for example):
Chassis 1 IO Module 1 (left) port 1 - FIC A (Port 1 ... for example)
Chassis 2 IO Module 1 (left) port 1 - FIC A (Port 2 ... for example)
Chassis 1 IO Module 2 (right) port 1 - FIC B (Port 1 ... for example)
Chassis 2 IO Module 2 (right) port 1 - FIC B (Port 1 ... for example)
Cheers
Nuno Ferreira
06-18-2010 10:04 AM
Hi Terence.
Cheers
Nuno Ferreira
06-18-2010 10:40 AM
Thanks Nuno. It looks like I had them crossed incorrectly then. I'm running 2
cables from the IOM and configuring them as a 2-link (not 1 or 4). I've switched the connections to:
Chassis1-IOM1(1,2) connected to Fabric1(1,2)
Chassis1-IOM2(1,2) connected to Fabric2(1,2)
Chassis2-IOM1(1,2) connected to Fabric1(5,6)
Chassis2-IOM2(1,2) connected to Fabric2(5,6)
Thanks.
06-18-2010 10:48 AM
I just swapped out the connections and made sure all the links are back up but the connections I swapped are now indicating there is a FEX mismatch with a status of link up.
06-18-2010 11:33 AM
I ended up fixing it by reacknowledging the chassis.
06-21-2010 01:43 AM
Nice one Terence .. Glad to help.
Nuno Ferreira
