03-13-2012 02:54 AM - edited 03-01-2019 10:19 AM
It seems to me that with UCS manager 1.4 und upper, it is possible to configuration the IOM pinning via 1 port-channel.
I could not find any configuration guide about this kind of configuration.
Could you help me and/or inform me about this subject ?
many thanks in advance.
Nicolas.
Solved! Go to Solution.
03-13-2012 03:01 AM
Hi Nicolas,
+ The feature is avaiable only with 2.0 and the 2.0 hardware i.e. a combination of 62xx FI and the 22xx IOM.
the option is available on the same page as the chassis discovery policy page.
Equipment tab -> Select Equipment -> Policies (right) -> global Polocies -> Link Group Preference
./abhinav
03-13-2012 03:01 AM
Hi Nicolas,
./abhinav
03-13-2012 03:23 AM
Hello Abhinav,
Many thanks for your clear and prompt answer.
So with UCSM 2.0 and 62xx FI and 22xx IOM, is-it the best practice to configure the IOM pinning via port-channel ?
Many thanks.
nicoals.
03-13-2012 03:37 AM
Glad it helped Nicolas!
No specific recommendation or best practice but if you are running an environment with that particualr hardware it will be a good option to choose for all the benefits it provides.
./abhinav
03-13-2012 03:42 AM
Many thanks for your answer.
Have a wondefull day.
Nicolas.
