IP Pools issci initiator pool - Question
Ben Morgan
Level 3
Level 3
Im trying to expand my IP Pool for the iscsi iniatiator pool. The modify button is greyed out. However When I go to create an additional Block of IP Addresses, the UCS system returns an error "Failed creating [ip address range]. cause: object not found, object of class vnicIPv4PooledISCSIAddr with RN ipv4-pooled-iscsiaddr"
So question, does the UCS system allow you to either expand the IP Pool or create additional IP Address Blocks for the ISCSI Initiator?
UCS v2.0 (4b)
Ben
Leo Laohoo
Duplicate post.
Go here:  https://supportforums.cisco.com/discussion/12252521/ip-pools-issci-initiator-pool-question
