Im trying to expand my IP Pool for the iscsi iniatiator pool. The modify button is greyed out. However When I go to create an additional Block of IP Addresses, the UCS system returns an error "Failed creating [ip address range]. cause: object not found, object of class vnicIPv4PooledISCSIAddr with RN ipv4-pooled-iscsiaddr"
So question, does the UCS system allow you to either expand the IP Pool or create additional IP Address Blocks for the ISCSI Initiator?
UCS v2.0 (4b)
Ben
