IPMI changes
If an IPMI change is made through the CIMC (a USC C200 in this case), does this require a reboot for the changes to apply?  Or are the changes done on the fly?  For example, I would like to disable "Use DHCP" under Network/IPv4 Properties.
Thanks.
1 ACCEPTED SOLUTION
IPMI changes
You can make these changes on the fly.  It will not reboot the host OS.  Going from DHCP to static I don't even believe will cause the CIMC to reboot. Once you apply the setting you will lose connectivity until you reconnect with the new static CIMC IP.
Robert
IPMI changes
Robert
IPMI changes
Thanks Robert.
148
