Is it possible to change the port-channel load balancing policy on the FIs?
We currently have a 2 member port-channel from each of our 6248s up to a 6500, with src-dest IP load-balancing policy set on each side. We're running into an issue where 2 particularly busy servers are getting hashed to a single PC member, and that member is running at full utilization. I'd like to test with L4 balancing, but don't see where that policy can be set in the CLI. Anyone know if this is possible?
1 REPLY
Brad,
I don't think FI supports L4 load balancing on ethernet uplink port-channels.
6248-01-B(nxos)# sh port-channel load-balance
Port Channel Load-Balancing Configuration:
System: source-dest-ip
Port Channel Load-Balancing Addresses Used Per-Protocol:
Non-IP: source-dest-mac
IP: source-dest-ip source-dest-mac
Padma
367
